dell wireless 1390 wlan mini card
Discussion in 'Networking and Wireless' started by kunicorn, May 5, 2008.
  1. kunicorn
    kunicorn Notebook Enthusiast
    In the network setup wizard it says that the mini card is disconnected. I have an inspiron e1405 notebook. I set the restore point back to before I tried setting up a home network and I cannot connect to the internet to see if it need drivers updated. The connection won't repair itself either. I don't know what else to try since I can't get on the internet with that notebook. Any ideas?
  2. pixelot
    pixelot Notebook Acolyte
    Ethernet?
    (filler)
  3. kunicorn
    I'm sorry but I'm not sure what you are asking about the Ethernet.
  4. kunicorn
    I know what ethernet is but I'm not sure what you mean for my situation.
  5. pixelot
    Can you use it to get online?
  6. kunicorn
    No, I can't get it to connect in any way. When I search for wirelss networks it says I need to use the Wireless Zero Configuration service which I did and it still didn't get online-it keeps showing that message. When I troubleshot the mini card it says it is working fine but the Network Wizard says it is disconnected so now I don't know what to do.
  7. pixelot
    The ethernet. Can you use the ethernet to establish a connection?
  8. Wirelessman
    Wirelessman Monkeymod
    By ethernet pixelot means when you connect your laptop to the router via a cat 5 cable. We are just trying to isolate the issue.
  9. kunicorn
    I just connected it to my modem with the ethernet cable and it said it cannot connect. I clicked repair but it still didn't work.
  10. kunicorn
    When I run the network setup wizard it says my mini card is disconnected but I have no idea how to fix that or if it can be fixed so the wizard won't finish setup. When I ran the troubleshooter for the mini card-it said it was fine.
