Dell Vista Laptop Reformat and Bloatware Removal Guide
Discussion in 'Dell' started by Les, Aug 18, 2007.
  1. crash
    crash NBR Assassin Super Moderator
    Oh :eek:
    I would make your secondary partition and create a backup image of your OS partition. That way you can always revert back to a clean install setting if you need to.
    After doing that, I installed all my programs, did all the tweaks, and then created a backup image of both partitions (I have it all on an external hard drive).
  2. Widge
    Widge Notebook Consultant
    Haha! No worries, I'm one of the rare few who like to sit and hoover up info FIRST before asking away.
    Ah right, so plough on with my plan then. Partition off, make image and then tweak away.
    Is 8 GB enough? EDIT: No! I'm using 17GB after a clean install anyway! :D Looks like about 25GB...
    Gah, I've got no DVDs left, I'll have to put this on hold until I scrounge one up. OH actually, I'm being an idiot, I can make an image on the big partition and then burn to DVD at my leisure.
  3. crash
    What I would do :)
    I personally have my OS partition set at 35 GB, but I also have Office 2007 Ultimate installed on it. Those 2 things together total to be 20.4 GB currently, with a few more to be used by SP1 and future updates.
    :D
  4. kulboy
    kulboy Newbie
    reinstalled vista and did all the tweaks for my vostro 1500, thanks op. My only problem is that I can't get my wireless going. under other devices network controller has the question mark to it. i downloaded the 1390 wireless driver is there something else that i am missing. when i go into the dell wireless utility i get the error "the wireless network adapter could not be accessed". the switch is in the on position. i had it on my network before i uninstalled, i know i am missing something, please help. thanks!
  5. vitog123
    vitog123 Notebook Consultant
    thanks it worked!
  6. Widge
    Interesting, vista 'drive' sits there at about 19GB full.... I did an Acronis Image and that shows up as 5.34GB. I wonder if it compresses it?
    May get some DVD9's, get a 'fresh install' disc and an 'install with steam and ableton and fave programs' disc.
  7. darthsat
    darthsat Notebook Deity
    Excellent to hear.
  8. Beech
    Beech Newbie
    Hi
    One final thing...
    Do you need to install the Intel Matrix at the end even if you use the Dell OS disk?
    Ta
  9. NSFW
    NSFW Notebook Enthusiast
    Second time I've tried now.
    I follow the steps, and when windows boots up, I insert the dell media direct CD. Nothing happens. So I open it manually, open the dell kit folder and attempt to execute the dell kit program.
    It takes FOREVER to load, and then comes up with an Error message stating "Data Cyclic error, D: something something"
  10. Les
    Les Not associated with NotebookReview in any way
    That might occur if the original installation of MediaDirect was not completed.
    Can you confirm that you followed the steps by initially creating the partitions through the Mediadirect disk first, then reboot and install Vista, and only then put the mediadirect disk back in and find and execute dellkit?
