Dell Studio XPS 1645 Problems! Need help!
Discussion in 'Dell XPS and Studio XPS' started by Stalvros, Sep 21, 2012.
  1. Stalvros
    Stalvros Notebook Evangelist
    Hi guys, I got this dell studio xps 1645 at the moment.
    I've got major problem on this laptop.
    Without the charger, this laptop turns on fine.
    It goes to Windows 7, loads properly, able to do work and all and its good.
    With the charger, this laptop keeps getting the blue screen error.
    it just keeps restarting and sometimes it just shuts down by itself.
    I read somewhere that it's because it's HOT or something to do with the throtlle thingy, I don't know.
    What I wish to seek help is.
    What can I do in order to improve it's condition?
    Like, update the BIOS?
    How do you check if the adaptor is the 130 type and not the 90?
    I've been searching and havent found any solution with regards to this.
  2. namaiki
    namaiki "basically rocks" Super Moderator
    What are the temperatures as reported by HWMonitor when plugged in?
    As for the adapter type, what is the Voltage and Amperage that is listed on the sticker of the AC adapter? (e.g. 19.5V 4.7A which is probably 90 Watt)
  3. Stalvros
    Im using the program Core Temp 1.0 RC3 at the moment.
    It says;
    Tj. Max 100 C
    Core #0 91 C
    As for the adapter, it says
    Model: FA130PE1-00
    INPUT: 100-240V 50-60Hz 2.3A
    OUTPUT: (19.5V) 6.7A
  4. namaiki
    If the computer isn't doing much, 91C is very hot. HWMonitor should be able to give you temperatures of more components in your laptop. Perhaps you need to open up your laptop and clean it of dust etc.
    Service manual is easily available: Documentation (one of my favourite things about Dell).
  5. Stalvros
  6. gixer2000
    gixer2000 Notebook Consultant
    You need to read the tag on the adapter to know what wattage the adapter is
  7. Stalvros
  8. Stalvros
    I've got plenty of problems with this laptop now.
    I just switched it on again, it loads to windows,
    and right now it doesnt detect any drivers.
    My sound driver is gone
    Cannot load windows aero theme
    cannot connect to internet
  9. gixer2000
    Simple ohm's law answers your question. voltage x amperage = wattage(19.5x6.7=130.65)
    Now in the future you know how to figure it out
  10. Stalvros
    So I've got 130W at the moment.
    I've already updated my bios to the latest A07.
    And i'm still having lots of problems with this laptop.
    Any suggestions?
