Dell Precision M6600 Water Cooling - project
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by Hellsik, Jun 30, 2018.
Do you like this project?
  1. Yes
    26 vote(s)
    100.0%
  2. No
    0 vote(s)
    0.0%
  1. bennyg
    bennyg Notebook Virtuoso
    I'm close to finishing the metalwork stage of a fully internal wc mod for my P370EM. Making everything by hand from 6mm hvac copper pipe, flattening it to 3.5mm and replacing all the heatpipes and soldering double-45 degree U joins where tight turns are needed (like in the rads). I'm soldering it all to the original heatplates, so all the vrms will be watercooled too :)
    Never could find blocks that would fit and didn't look sketchy, the P370EM cpu is a beeatch stacked setup where the fan sits on top, with like 5mm clearance between CPU and fan housing. GPU2 also only has about 7mm height to bottom cover.
    I found a cheap dc 12v "ultra quiet <40dba" ~20mm high pump for testing that I should be able to fit in the optical bay.
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com.au/ulk/itm/273310251939
    Finding one that was both slim and didn't have an output pointing the wrong way took a while. This one also looks like it'll be good for dc voltage based speed control (minimum 6V).
    Haven't turned it on yet so don't yet know how much of a lie the noise or flow specs are ;p
    I'll have to fab my own res/air trap with a fill/bleed port. I think I might be able to do something with a urine container or plastic test tube lying around I can make something from. Air is a pain in small pumps, I rigged up a portable external rad/res with a teeny Alphacool DC-LT and when it cavitates, boy is it noisy, sounds like a bandsaw that's sucked on some helium.
    One other concern is the cheap vinyl tubing. Hopefully zip ties are enough to seal, but it also starts softening at 60C, and the 1070s and XM cpu can burn over 500W at peak...
  2. Hellsik
    Hellsik Notebook Geek
    I use same pump 12 and 6 volt. It is powered from USB and after that converted to 9.6 volt (max from USB it takes about 4,8 V and 0.8A). You dont need power it with 12V because the temperature of pump rise teperature of lope. Flow is geat and really quiet, almost no vibrations.
    Kyle likes this.
  3. Hellsik
    Here is new update. I create reservoir, but it has some leaks. Tomorrow I will create radiator with water block. Here some pics.
    IMG_20190302_124732.jpg IMG_20190302_124811.jpg IMG_20190302_125803.jpg IMG_20190302_153418.jpg IMG_20190302_183052.jpg
  4. Mastermind5200
    Wow! amazing!
    User32 likes this.
  5. Hellsik
    Sorry guys I must complete my final thesis. But now I will add more of pictures and graphs with results.
    In first place I simulated water blocks and radiators.
    GPU water blocks
    Radiators
    Kyle and bennyg like this.
  6. Hellsik
    For creating water blocks I choose aluminium old coolers from chipset motherboard
    Bez názvu.jpg .
    For radiators i use old aluminium CPU cooler
    Here is picture beforee soldering
    After soldering i had more leaks and I damaged CPU and GPU waterblock. So here is another solution. I use copper for cooling GPU (left side of picture)
    Kyle likes this.
  7. Hellsik
    Final result of worling water cooling laptop. It is look terible, but i need to complete this in time.
    Testing leaks and temeratures before adding bottom case and palmrest.
    Kyle and Rengsey R. H. Jr. like this.
  8. Hellsik
    On the biggest end the result. of temerature CPU. It was mesure with stress test OCCT. For water cooled CPU was temerature 69°C and average frequency 2,6 GHz from 2,4 GHz. For 2860QM temerature was 76 °C on base 2,5 GHz
    GPU temperature with stress test FurMark.
    And last is fan speed.
    luixyz, Kyle, Megol and 2 others like this.
  9. yosv211
    yosv211 Notebook Consultant
    How did you make the water blocks for the laptop. Do you have your own machining tools.
  10. trackerPoint
    trackerPoint Newbie
    very cool, hope u did well on your project. I have two of these 6600's with the amd 6100's. Can't wait for water cooling in the future, imagine a 2.5 lb laptop with an rtx 2080 lol
