Dell Precision 7720 Bios bricked need help repairing dump
Discussion in 'Dell' started by code9523, Jan 18, 2019.
  1. Vasudev
    I reckon you did format the usb drive as fat16 and copied only few dell files and then only the hdr file, correct?
    Maleko48 and custom90gt like this.
  2. code9523
    code9523 Notebook Enthusiast
    Guys! The problem is solved! I found a site with dumps etc http://schematic.vn/ just need to subscribe there for 12$ and the admin will fix your bricked bios dump. This is not an advertising just my experience! The laptop booted fine but after couple attempts.
    kaibsora, Maleko48 and Vasudev like this.
  3. Vasudev
    Go into BIOS options and check if BIOS Flashback tech or BIOS recovery is enabled or not? I think it was disabled. Usually on most business laptops and workstation they are disabled to prevent downgrades.
    Maleko48 likes this.
  4. kaibsora
    kaibsora Notebook Consultant
    they even had what i need for my 7710! woohoo!!
