Dell Power Manager
Discussion in 'Dell' started by AlexanderKim, Sep 22, 2018.
  1. AlexanderKim
    AlexanderKim Notebook Guru
    Does it actually work? I've set a setting to using primarily AC, and my charge stays at 100% all the time, does it work?
  2. John Ratsey
    Do you have a Settings button on Power Manager's Battery Information page? This, if it's there, lets you configure the custom charging settings. I know the button there on Dell's business notebooks but don't know whether the consumper products support this facility.
    John
  3. AlexanderKim
    This one, you mean?
  4. AlexanderKim
    Also i have this setting
  5. DoctorRzepa
    DoctorRzepa Notebook Guru
    I believe it has to "learn" how you use your laptop to apply any tresholds.
    I just set it to start charging at 60% and stop at 65%.
  6. AlexanderKim
    I just switched to custom setting - 60% - 80%. Drained down to 79% and seems like it's indeed working, it stopped charging.
    is that ok for battery?
  7. DoctorRzepa
    It's better than keeping battery at 100%. You can find useful info about li-ion batteries at batteryuniversity.com.
    Lower the charge, longer it stays healthy.
    AlexanderKim likes this.
  8. AlexanderKim
    So 80% looks ok?
  9. DoctorRzepa
    In my opinion ~60% is better. That's even stock setting for battery preserving on lenovo's.
  10. Vasudev
    Better stay away from setting anything. Run it at full 100% power. W10 doesn't charge battery quite often after they made Surface Books. Only if battery % drops below 95% only then it'll charge otherwise you'll see Fully charged message.
