Dell M6600 problem witch BSOD, RSOD, freeze and restart
Discussion in 'Dell Latitude, Vostro, and Precision' started by Hellsik, Nov 23, 2014.
  1. Hellsik
    Hellsik Notebook Geek
    Hi,
    I have problem with my Dell. I have Windows 7 Pro x64. Intel 2929XM, AMD 8900m, 8GB RAM, and Seagate XT 500GB 1.st generation. I have original adapter Dell 240W (slim edition) and i do not have battery. My Dell is without battery, LCD, Wifi.. It is only chassis with MB and ect..
    I have a few problems like BSOD errror code 0x00000124 and 0x00000101.
    Next is RSOD with freezing or restarting system.
    Next is only freeze and i must shutdown NTB and start.
    A last point is only random restart.
    I first install Windows 7 x64 and i have ramdom freeze, restart and BSOD.
    I flashed bios to A15. reinstall drivers.
    Everything was same.
    After that i install Windows 8.1 Pro
    When i play World of Warcraft it was do samething.
    I flash vBios and reinstall Catalyst and driver for 8900m and M6900 series for MS, but i still had RSOD.
    I reinstall to Windows 7 Pro x64.
    Install only drivers and directx i play first 4-5 hours i was ok but BSOD cames error 0x0000124.
    I reflash vBios and reinstall chipset driver for lastest from dell. I tested chipet from Intel but it was same.
    In BIOS a tested every settings. From Enable SpeedStep, Turboboost. to Disable SpeedStep, Turboboost. When i was test this thing a reinstaling ACPI driver. But I got BSOD 0x00000124 or onetimes 0x0000101.
    Big point is when i enable speedstep procesor goes to 800MHz but not hight. When i disable SS, then cpu goes to 2,5Ghz. I remove dell SW for display, battery and Power Manager. Processor was on 2,5GHz but i still got BSOD.
    I play World of Warcraft and it is randomly sometimes i play 3 hours and nothing and sometimes i play 10 minutes and i have freeze or BSOD.
    I cleaned fans and used new thermal past. Run Memetest86 for 3cycles, Intel Burn Test for 10 hours, and GPU stress test for 3 hours with Intel Burnt Test or without.
    Dell test in bios it was ok. Only battery not pass. (I do not have battery).
    Please help me i tested everything as i can.
  2. Lnd27
    Lnd27 Notebook Evangelist
    Are you tested your hard drive?
  3. Hellsik
    Yes, but only in smart test and everthing is ok. In my second NTB works great without errors.
  4. Lnd27
    is this problem only with World of Warcraft ?
    couse your test results are ok (Memetest86 for 3cycles, Intel Burn Test for 10 hours, and GPU stress test for 3 hours with Intel Burnt Test or without)
    i can recall that when i played wow-pandas, i have some gpus error too( it was on quadro 3000m)
    are you did clean install of gpu drivers?
    also . may be something was wrong connected? or havent full contact(
  5. Hellsik
    Maybe a solve this problem with diseable "C States" in BIOS. I do not have problem for 3 days.
    Lnd27 likes this.
