Dell Inspiron speakers not working, any help why?
Discussion in 'Dell' started by PetecustomVaio, Jun 17, 2006.
  1. PetecustomVaio
    PetecustomVaio Notebook Enthusiast
    Hi,
    The Inspiron's speakers intermittently stop working until finally they just didn't work. The strange thing is sound works well with headphones or external speakers. Any guesses on what's wrong? The volume button has been checked, mute setting have been checked. The sound pretty much works perfectly from headphones so that suggests hardware problems with the speakers? The computer shows all audio and speaker drivers are properly installed and functional. It just passed the 1 year warranty period.
    Not much comes up when I do a forum search for broken speakers. Have any of you guys seen a similar case with other Dells? Anyone know how much this would cost to repair? Perhaps someone knows how to physically go in and replace the speakers. Would a full system restore be an unfavorable last resort? Thanks guys.
  2. Amber
    Amber Notebook Prophet NBR Reviewer
    I had the opposite. My speakers worked great, but my headphone jack was screwed up. My guess is that it is hardware. You could try to fix it yourself if you don't want to expand your warranty. Another option is just to get a portable speaker set and use that.
  3. Brian
    Brian Working at 486 Speed NBR Reviewer
    Sounds like an equipment fault to me. I wouldn't bother with software related stuff, don't think that will help. I guess the better question is what's it worth to you to get them fixed? I don't see any round trip to Dell for service being under $100.
  4. nlm_murthy
    nlm_murthy Newbie
    i have the very exactly same problem..Let me know if anyone has ideas to fix this...Please email to nlm_murthy@yahoo.com
  5. da_17
    da_17 Notebook Enthusiast
    I heard a friend of mine telling me that same probelm with his computer... It is an Inspiron 6000, and it happened about a week after the warranty expired. He told me it wasn't all the time at first, and that sometimes when he moved the computer around sound came back, but I think now it is permanent.
  6. Amber
    Most likely,the motherboard needs to be replaced. If he can't afford that and if the headphone jack is working, buy a good pair of portable speakers and use them.
  7. Bethany
    Bethany Newbie
    OH NO! The same thing has just happened to me and I was hoping it would be an easy fix! Right now I found that if I stick a paper clip in the ring around the headphone jack, that it brings the sound back. It makes me wonder if it has something to do with the position of the headphone jack...
  8. Dalantech
    Dalantech Notebook Consultant
    The headphone jack acts as a pass through connection for the speakers. When you plug in the head phones you push two pins apart that breaks the connection to the internal speakers and when you unplug the head phones those two pins "relax" and reconnect the speakers. Sounds like that pin is not relaxing all the way and the connection to your internal speakers is broken. You might be able to get to the head phone jack and bend the pins back together, but it will violate your warranty and I'm not responsible for any damage that you do to your laptop...
  9. dentalyogi
    dentalyogi Newbie
    Hi there guys.
    Last week my inspiron 6400 had no sound except for the annoying internal beep! In control panel, my sound device cannot be found! Also, my bluetooth manager in control panel is no longer there!
    Any solutions to this? Any help would be much appreciated!
    Thanks.
    ps - anyway of turning off the beep???:eek:
  10. nizzy1115
    nizzy1115 Notebook Prophet
    Old thread is really old! Please do not revive dead ones...
    In help though, reinstall your sound drivers...
