Dell Inspiron 15r N5110 graphics card help
Discussion in 'Dell' started by SBD02015, Apr 14, 2011.
  1. SBD02015
    SBD02015 Newbie
    So I just received the new Inspiron 15r N5110 from dell specs are:
    Core i5 2410M second gen
    4GB Dual Channel DDR3 SDRAM at 1333MHz
    640GB2 SATA hard drive (5400RPM)
    1024MB NVIDIA® GeForce® GT525M
    I am slightly confused about the graphics card it's meant to be the GT525M but when i go into system specs it says its a Intel(R) HD Graphics Family with only 64mb of dedicated memory when its meant to be 1GB.
    It also says the graphics card is a Intel(R) HD Graphics Family when i use cpuid and other applications.
    But when i go into device manger under display adapters it says GT525 is there.
    So is the graphics card enabled or I am I just using the integrated graphics alone?
    PS: I've played crysis, cod4, halo 2 and they work fine on medium to high settings.
    Thanks
  2. Tsunade_Hime
    That would be Optimus at work. Do you have all the latest drivers?
  3. SBD02015
    SBD02015 Newbie
    Can you explain how Optimus works?
    i haven't installed any drivers since i got it yesterday and there are no updates on their website
  4. Tsunade_Hime
    Basically when Windows detects you aren't using your GPU for intensive tasks it will switch to the Intel GPU to save you battery/heat. But there are many documented issues with Optimus. That's why I asked if you tried the latest Nvidia/Intel drivers. Sometimes it will ship with old drivers.
  5. SBD02015
    SBD02015 Newbie
    Oh ok thanks for the help. the GPU is fairly new so i hope its ok. Also is there any way to completely switch over to the GT525?
  6. SBD02015
    SBD02015 Newbie
    It's ok i found the control panel so I can switch it on and off and set programs to run on the GT525 which is pretty good
  7. skarlso
    skarlso Newbie
    Hi.
    Can you tell me how do you exactly switch it on and of? Is there a way to swtich the other one off maybe?
    I couldn't find that setting anywhere...
    Thanks!
  8. ngkhanmein
    ngkhanmein Notebook Enthusiast
  9. alionger
    alionger Newbie
    I face problem with this Dell N5110 core i7 its the VGA
  10. markozutic
    markozutic Notebook Enthusiast
    Hey, does yours palmrest gets also hot when gaming and surfing?
    in gaming it gets way hotter and unpleasent to use..?
