Dell e7450 no audio out of speakers, but headphones work
Discussion in 'Dell' started by Jason, Feb 10, 2019.
  1. Jason
    Jason Overclocker NBR Reviewer
    Hello everyone,
    Long time member of NBR, but I've not posted here in years.
    Anyways, I have a Dell e7450 ultrabook that I used mostly in my office/lab and it is plugged in 99% of the time.
    I've always had it hooked up to speakers through the 1/8" jack. About 6 months ago, the entire computer just shut off and would never boot up again until Dell replaced the motherboard under warranty.
    I just noticed recently (after the warranty expired) that the internal speakers do not work. I wanted to reformat it anyways, so I loaded a fresh copy of Windows 10 on the laptop and downloaded the realtek audio driver.
    Sound works great out of the 1/8" audio jack when connected to speakers or headphones but does not work out of the internal speakers. I've looked at BIOS settings and I've also run the Dell ePSA diagnostic tool which passed. However, it seems previous versions of the ePSA tool did an audio test, I'm not seeing an audio test in the version built into my laptop. I'd like a way to test the speakers so I know if there is a hardware failure or not. Part of me wonders if when Dell replaced the motherboard if possibly they could have forgotten to plug in the speakers?
  2. ALLurGroceries
    ALLurGroceries   Super Moderator
  3. OSihota
    OSihota Notebook Enthusiast
    To be honest I've forgot to plug the speakers in a time or two myself. In your case, because speakers are pretty cheap online I might just order a second set just in case they are broken. In the end you can always just list them on ebay to get your money back if you don't need them.
