Dell 9370 Killer WiFi 1435 Issues and Problems
Discussion in 'Dell XPS and Studio XPS' started by borse2008, Jun 12, 2018.
  1. borse2008
    borse2008 Notebook Consultant
    Hi there
    Has anyone got any fixes for the Killer WiFi 1435 lag issues and slow performance and what workaround have you taken.
    Sent from my ONEPLUS A6003 using Tapatalk
  2. backslashfr
    backslashfr Notebook Enthusiast
    Totally interested in that thread !
    Huge drop of internet performance navigation on my new XPS 15 (with killer 1535) (coming from Intel 6235, using same network)
  3. John Manuel Costas
    John Manuel Costas Notebook Enthusiast
    Seems like the best move is to buy the intel card and install it. Since I'm getting mine in a few weeks I'm going to just do that right when it comes in. Such a ridiculous thing only dell would do on a high end laptop.
  4. backslashfr
    Which Intel card do you recommand ?
  5. John Manuel Costas
    Edit: got the wrong model
    Intel 9260 AC seems to be the one of choice, seems like a very cheap solution to one of the annoying quirks with these. I plan on adding this, a new SDD in time, and a repaste to mine if everything goes well after the first 30 days. I will do the wifi card regardless since its fairly cheap and easy to remove and return if i decide to return the dell.
    https://www.amazon.com/Intel-Wirele...pID=51BF3bhIM7L&preST=_SY300_QL70_&dpSrc=srch
  6. custom90gt
    You can't replace the wireless card in the 9370
  7. custom90gt
  8. John Manuel Costas
    Im realy sorry I misread this at 9570 folks, apologies! Off to a nice start here
  9. Eason
    Eason Notebook Virtuoso
    I talked to my contact at Killer about this; the latest BIOS update should fix this issue in the XPS 13.
  10. Devhux
    Devhux Newbie
    The other issue is the Wi-Fi just doesn't work after resuming from sleep mode sometimes - you have to go through the network troubleshooter to fix it (or reboot).
    Sent from my SM-N950W using Tapatalk
