Delid an Ivy Bridge in a P170EM, yes, no?
Discussion in 'Sager and Clevo' started by eriannmx, May 2, 2017.
  1. eriannmx
    eriannmx Notebook Consultant
    I just learnt this is a thing. With a delidding tool it looks like a breeze. CPU's get up to 80° when fully used.
    So, should? Shouldn't I? Is this even possible or necessary in a P170EM?
  2. Carrot Top
    Carrot Top Notebook Evangelist
    You can't. Mobile CPUs are bare die. No IHS to de-lid.
    jaybee83, Papusan, ajc9988 and 2 others like this.
  3. eriannmx
    I was too lazy to open up the lid to double check, but that explains the service manual image I was looking at. It's just that I read people talking about delidding in this forum so...
    Thanks for the info :)
  4. Carrot Top
    The people talking about de-lidding in this forum are referring to more recent Clevo models, some of which use desktop instead of mobile CPUs. Those model numbers generally start with P7 and P8.
    jaybee83, eriannmx and Aroc like this.
  5. Meaker@Sager
    Yes all the HQ/HK/HQ/XM models are all bare die, only the desktop chips have lids to protect them from high pressure desktop heatsink mounts.
    Aroc likes this.
  6. bennyg
    bennyg Notebook Deity
    If you want better temps try liquid metal. My P170EM with a badly fitting heatsink and conductonaut, with a 3720QM pushed as far as it can go (prema bios partial unlock no power limit) the hottest core stays under 80C stress tested on max fans.
    Pic shows idling after IBT completed.
    Holds 3.8GHz multicore, 4.0 max turbo (@ 1.22V)
    Max package power 65W
  7. eriannmx
    Wouldn't the LM spill without the lid? Or how do you prevent this spillage?
  8. bennyg
    The metal part of it forms an oxide 'skin' in contact with air. When the gap is small enough this is enough to hold it in place.
    If the gap is too large this may not be enough to hold it. But by far the biggest cause of spills out the side is using too much
    eriannmx likes this.
