Deciding between these 2
Discussion in 'What Notebook Should I Buy?' started by AndresHdz, Nov 20, 2018.
  1. AndresHdz
    AndresHdz Notebook Guru
    Hi? I’m searching for a new laptop for this.
    3ds Max (videogame modeling and lsome rendering )
    Unreal Engine (Video game design and programming)
    Photoshop
    Little Video Editing
    Zbrush for modeling
    After navigating stores and stores my Options are up to 2 finalists.
    Asus
    https://www.notebookcheck.net/Asus-...Radeon-RX-580-FHD-Laptop-Review.281526.0.html
    Ryzen 5 1600
    8gb RAM
    Rx 580 4gb
    No ssd
    1Tb hdd
    Helios 300
    https://www.notebookcheck.net/Acer-...-GTX-1060-Full-HD-Laptop-Review.242962.0.html
    I7 7700hq
    16gb ram
    Gtx 1060 6gb
    128gb ssd
    1tb hdd
    I would appreciate your help
    Prices are nearly the same
    ALSO for economic reasons i can’t afford any upgrades in the near future
  2. Blacky
    Blacky Notebook Prophet
    I think you posted here before: http://forum.notebookreview.com/threads/which-would-you-recommend.825907/#post-10822047
    So for the Asus GL702ZC, you have the same issues I mentioned earlier:
    The Acer Predator Helios 300 PH317-51 is actually not a bad choice. The version with the 7700HQ could have its processor cooling improved, but it wasn't bad, if you replace the thermal paste with something better, like Gelide Extreme, then you have a pretty good laptop.
    Here is a comparison between the two: Asus GL702ZC vs Acer Predator Helios 300 PH317-51 .
    So my vote goes for the Helios 300 with the 7700HQ processor.
  3. AndresHdz
    Thanks, so you think the Helios is a better choice.
    Yeah, I posted before but I didn’t mention the exact models and wasn’t very clear
  4. Blacky
    Yes, I would definitely say the Helios is a better choice.
  5. AndresHdz
    Thanks blacky, I will go for that one
  6. AndresHdz
  7. AndresHdz
    I find it a suitable option
  8. Blacky
  9. AndresHdz
    Size is not an important issue to me for now, so between the ASUS and the Y720, the Y720 is better for what I want? What do you think ?
  10. Blacky
    You mean the Acer, not the Asus. Right?
