Decently portable, solidly-built laptop for general use, light editing/gaming
Discussion in 'What Notebook Should I Buy?' started by OlegRU, Feb 18, 2017.
  1. OlegRU
    OlegRU Notebook Geek
    General Questions
    1) What is your budget?
    $600-800 (as long as I can finance it)
    13" and up
    USA
    a. Like:
    b. Dislike: Acer seems to make crappy built stuff, but I'm no computer expert.
    Prefer to go new for this pricepoint
    Business/school/general use with multitasking, light photo/video editing and some light/occasional gaming
    I'm looking for something decently portable - both
    I haven't played games for a while, but would like the ability to play if I had the time/desire. I'd like to run at least up to games from 2011 (i.e. Dragon Age II, Mass Effect 3 and older) on good settings, and older games (i.e. Dragon Age: Origins, ME 2) on high.
    My laptop that just died had a horrible battery, so would be great to have a battery that could last like a workday or something, if I was doing non-intensive things such as browsing, typing etc.
    Whatever is the best deal and I can finance.
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    At this price, I'm assuming Windows is the way to go.
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    Seems like 1080 is the new standard
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Not sure - I like a vibrant display, but maybe one that has good enough display that glare is not an issue even if it's a glossy one...? (sorry for the newb answer lol)
    Build Quality and Design
    Not really
    ASAP
    Several years
    Notebook Components
    Would like an SSD of course, but depends on price. Perhaps the 8GB SSD/HD combo so things load and work fast but save money. I want it to hold data, but with a good enough laptop, I guess I could get an external HD.
    No
  2. OlegRU
    anybody?
  3. Critical Observer
    Critical Observer Notebook Enthusiast
    Several well-specced Thinkpad E570 and a few E470 that fit your budget in the Lenovo outlet; criteria used:
    - New
    - 1080p display
    - dedicated GPU
    E470 (14") is fairly portable, E570 (15") slightly less so. Both are of robust build especially considering the price-point and the keyboards are the best in class as well. Both are available with dGPU, E470 with 940MX and E570 with 950M, that should make older games quite playable.
    There are also some Ideapad 700 and Ideapad y700 in the outlet, with quad core Skylake CPUs, lesser build-quality and less portability compared to the Thinkpad options above. I must say this one http://outlet.lenovo.com/outlet_us/itemdetails/80RU00CYUS/445 looks like a whole lot of computer for a very reasonable price to me (but then, all of these appear astoundingly cheap to my European eyes).
  4. OlegRU
