Dashcam recommendation
Discussion in 'Off Topic' started by saturnotaku, Jul 12, 2018.
  1. saturnotaku
    Looking to purchase a dashcam. Would like to be able to record minimum 720p, preferably 1080p video, use a microSD card, and be easily movable among vehicles. Having a monitor to see what's recording would be extremely helpful as well. I'm open to using a GoPro or similar device that would be better from a portability standpoint, but I'd prefer not to spend that much. Less than $200 is good, less than $100 even better. Recommendations are appreciated.
  2. Syndrome
    Syndrome Torque Matters
  3. Jarhead
    Jarhead 恋の♡アカサタナ
    I personally use a Thinkware X300, which would hit all your points except maybe the mobility between cars (it attaches to a base that adheres to your windshield).
  4. saturnotaku
    Yeah, that's not going to work. The cam would need a suction cup mount because it would be moved at least once a week.
  5. Datamonger
    Datamonger Notebook Evangelist
    I have a solution to that. Remove the original adhesive, clean mounting bracket with isopropyl, and apply this velcro-type stuff (similar to what's pre-applied to the back of a Fastoll), and mount to the windshield. I use the same type of setup so I can move my dashcam between my 2003 Sierra and 1992 Silverado. Everything holds just fine.
  6. saturnotaku
    That won’t work in my specific situation because I review cars, which has me switching into new ones every week.
  7. Datamonger
    Maybe one of those dashboard mat things that are intended for GPS units?
  8. saturnotaku
    This was the one I ended up buying. Paired it with a 64 GB MicroSD card and it's working pretty well. Image quality in mixed light isn't the best, but I can't complain for the price.
