D901C Webcam: Need compatible 32-bit driver for Win7
Discussion in 'Sager and Clevo' started by Pimpaholic, Feb 27, 2011.
  1. Pimpaholic
    Pimpaholic Notebook Consultant
    I've tried installing the vista drivers but no luck. The drivers install but after pressing fn+10, it's not recognized by any program, even the included Bison program.
    Going to attempt d900f drivers, but have my doubts (3m v 2m).
    Anyone with a similar setup get this to work?
    Thanks,
    dp
    EDIT: No luck. Tried vista and win7 d900f drivers.
  2. pasoleatis
    pasoleatis Notebook Deity
    Hello,
    I am running win 7 in vmware. I used the drivers I found on the Internet. Please keep the webcam on when you install the drivers.
    I upload what I used on rapishare. http://rapidshare.com/files/450292398/WEbCam.zip Install all 3. If it works in vmware it should work for you as well.
  3. MrDJ
    MrDJ Notebook Nobel Laureate
    where are you downloading your drivers from? and have you tried sager.
    they dont have d901c but they have various versions of 900c & f
    look HERE
    (SKU D900C) NP9260
    (SKU D900C) NP9261
    (SKU D900C2) NP9262
    (SKU D900F) NP9280 New Update
    (SKU D900F2) NP9285 New Update
  4. Pimpaholic
    Thanks for the upload, I managed to get it working with just the first driver! I appreciate it.
    @MrDJ:
    Yes, I tried them, as well. They have the Bisoncam stuff and I needed the Sertek driivers. Thanks though :)
