D900F/NP9280 Freezing, Flashing, HELP!!!
Discussion in 'Sager and Clevo' started by FlameHaze, Jul 31, 2016.
  1. FlameHaze
    FlameHaze Notebook Consultant
    Making a separate reply because this doesn't look right... I spent hours on google... Isn't there supposed to be a part here, the solder joints look busted and on google, all the D900F's have one... 1470134205770768296688.jpg
  2. sirana
    sirana Notebook Deity
    I think you could try both cards, given that the 680M also works. Just make sure you have the latest BIOS *and* EC flashed. I don't think you need to flash a vbios though, modifying the driver inf should be enough! I could help you with that, also wrote a quick guide on that. As long as you don't stress it in games it should not exceed your PSU capacity I guess!
    Also, for that soldered connection I'm not sure how it's supposed to look like as my x7200 is slightly different.
    Edit: According to Eurocom you just need the latest bios for the 680m to work, so this counts probably also for the 580m, while I couldn't find information on people who did that before (in contrast to quite a few people who ran a 680M).
  3. FlameHaze
    I have the latest bios and EC from Prema, but I have only the 75W heatsink.
    Also I can mod the driver inf :) its how I made it work in the other laptop.
    I do have a uhhh... Problem.... My D900F is... Not working now. I took the 285m out of my other laptop, popped it back in the D900F, pressed power and now I have no image... Is it dead now? I can't even think of what went wrong. I reseated the ram, and CPU, and GPU with Jo change, no beeps, no flashing lights, just the Bluetooth/WiFi light is lit orange(Bluetooth)
  4. sirana
    Does the card still boot in your other laptop?
    When my 680m was 100% dead it also showed me a black screen without beeps.
  5. Meaker@Sager
    It could be a static charge or a solder joint finally giving way, it's hard to say.
  6. FlameHaze
    Card posts in the other laptop perfectly fine
    The D900F doesn't react to anything, just power light comes on, fans go to normal speed, FN+1 still maxes the fans, but it never posts, the CPU isn't even producing heat, popped the W3520 back in, no change, swapped ram, no change, idk what else to test... I think the main board died... I smell burned electronics now too... I think something shorted
    Prior to all of this happening, my D900F wouldn't power up on battery unless I held power down, pushing power momentarily would cause the powerlight to come on for a 1/10th of a second and then turn back off... I assume something shorted or something on the board... I mean I kinda have to replace it now right?
    I only see eurocom carrying it for a nice affordable 595 USD... Ouch...
  7. sirana
    Bake/reflow it, no harm done if it's already dead, you can't make it 'deader'. Preheat an oven to 385F (close to 200°C) and leave the board in there for around 8-10 minutes, remove all plastic before and mount the card on some crumbled tin foil pillars. I believe in your baking skills ;)
    All is not lost yet.
  8. FlameHaze
    I've reflowed before, I'm doing it as we speak, will post results when done!!!
    I was supposed to add olive oil and some salt n basil leaves right?
  9. FlameHaze
    Baked the board, no changes at all. System won't post. I'm digging my mPCI-E post card out maybe it will say something but I am 100% sure the motherboard is shot... Now need help sourcing one, I was gonna buy it from eurocom seeing they are the only ones carrying it but the price is unreal...
  10. sirana
    For that outrageous price it's already worth saving for a new Pascal based Laptop... Sorry you couldn't make it work, maybe try again? Some said it took them three turns of baking/reflowing, you might try turning the board upside down.
