D630 won't start up
Discussion in 'Dell Latitude, Vostro, and Precision' started by r.bartlett, Sep 18, 2010.
  1. r.bartlett
    r.bartlett Notebook Enthusiast
    Guy's
    came down this morning to find my D630 won't start,
    |No power light or anyother lights and the screen stays blank and no HDD noise can be heard. I held the on/off button down for 20 sec's to force a restart but stiil no joy
    swapped the battery for a known good one -same thing
    I've searched the Dell support but nothing as yet
    MB gone perhaps :-(
    Cheers
    Richard
  2. John Ratsey
    Try taking out and replacing the RAM. Sometimes the contacts oxidize which removal / replacement will fix and, if the BIOS can read the RAM properly then nothing starts.
    John
  3. r.bartlett
    many thanks for the reply but as nothing happens at all I would have thought the start process would begin then shut down on 'no ram' rather than as mine is -bricked :-(
  4. John Ratsey
    I'm aware that a RAM problem normally causes a few flashing lights. However, computers don't normally terminally die overnight unless subjected to external influences (eg power surge, dropped). Dismantle and reassembly may clear a poor contact somewhere and get it working.
    John
  5. GKDesigns
    GKDesigns Custom User Title
    Sounds not good. How about pulling the battery and trying with charger power only. Also remove any other connections and devices that you can (such as ODD) in the event a bad item is pulling everything down.
    GK
  6. r.bartlett
    Tried everything but still dead .
    Phoned Dell support for assistance and questioned the warranty as some MB's were known to overheat and fail due to the graphics.
    He said no warranty (as the Dell website states) but I questioned that and he came back with the fact that the warranty runs out in October this year so an engineer will be coming round my house tomorrow to fix FOC!
    I know Dell get a lot of stick but I can't fault them :)
    Cheers
    Richard
  7. Robin24k
    Robin24k Notebook Deity
    The warranty on the motherboard has been extended for an additional year for D620 and D630 with Nvidia graphics. It doesn't show officially, but once the rep is aware of this, they will send out a motherboard without issue.
  8. r.bartlett
    That's why I questioned the warranty. However the record shows the start date as 4 October 2007 and as it's a 3 yr warranty the end date should have been Oct 10. However it stated "No warranty with this unit" Which is why he went away and looked into it. Then came back and said their engineer will be out tomorrow (today) to fix it as it is a 3 yr onsite warranty not RTB :)
    as an update. I tried it this morning just to see and it started up. However it was going a bit mad and half the keyboard doesn't work. It restarts itself again and again then some fully beeps come up :)
    Thanks to all
    Richard
  9. HT32BSX115
    HT32BSX115 Newbie
    Howdy,
    Old thread. did you fix it?
    I had a similar problem with my XFR D630.
    It all of a sudden would not power up at all......... pressing the power button would only cause the power "light" to flash briefly and go out.
    Strangely, it now powers up after being off for a few days. battery state or power supply connection didn't seem to make any difference.
    I have no warranty either. so the fix is all on me. I can buy a new mobo from ebay I suppose, but I'd like to know if someone else has had this problem.
    If it had not started working, my plan was (and still is) to take it apart and re-seat ALL the connections including the CPU to see if a poor connection was causing this.
    OS: Linux 2.6.34.7-0.7-default x86_64
    System: openSUSE 11.3 (x86_64)
    KDE: 4.4.4 (KDE 4.4.4) "release 3"
    Vendor: Intel Corporation
    Model: 965 GM
    2D driver: intel
    Anyone else with a problem like this?
    Cheers,
    Rick
  10. Robin24k
