crysis 1 and artifacting
Discussion in 'Gaming (Software and Graphics Cards)' started by JRE84, Mar 9, 2020.
  1. JRE84
    JRE84 Notebook Deity
    I only play 2 games and crysis is one of them.
    Im randomly getting a black or colored bar showing on the screen as though its artifacting from heat.
    My temps are 63c
    I reinstalled crysis
    I installed newest intel drivers
    I installe direct x august version
    I installed c++
    its from the uhd 620 i5 8250u graphics igpu
    Iv'e been pc gaming for twenty years and can usually solve my own glitches but for this im out of ideas and maybe im forgetting something but help would be greatly appreciated.
    picture below of artifacting
    https://ibb.co/yWzcCms
  2. JRE84
    Ok so i Installed THPS an older game with older versions of direcct x and c plus plus and it seemed to fix the problem...whew good thing I know my way around computers.
    Mods please delete this thread
  3. JRE84
    it actually ended up being the fact i was using aa and when i turned off anti aliasing problem went away. intel drivers are and have always been buggy
    Mr. Fox likes this.
  4. TR2N
    TR2N Notebook Deity
    I'd be cautious.
    Crysis will expose any underlying hardware fault in your setup.
    Based on the image uploaded, I cant see any artifacting, but be aware other games won't push your hardware to the extreme as Crysis does.
    Keep an eye on it and good luck.
    Mr. Fox and JRE84 like this.
  5. JRE84
    In the picture its right across where the water meets the sand.
    I'm aware of artifacting in crysis not being a good sign but I think this time its software related. thanks alot for the help bro
    Mr. Fox likes this.
  6. Mr. Fox
    Just think how much the remastered version might push it. Should be interesting to find out.
    But Can It Run Crysis?
    TR2N and JRE84 like this.
  7. JRE84
    i'm a bit skeptical as it's coming out for the nintendo switch. Hopefully they have low to veryhigh settings again and the switch ps4 ect are running on medium, if this is the case then thats the ticket, should be amazing.
  8. Spartan@HIDevolution
    Do you have a Switch? Please tell me about it
  9. JRE84
    ?no?
    the switch isn't powered by a 2080ti and thats the gpu requirements crysis remastered should be gunning for
