Create recovery media won't work
Discussion in 'Lenovo' started by bobfff, Jan 12, 2008.
  1. bobfff
    bobfff Newbie
    Thinkpad X61. XP2 installed. I tried to use create rescue media in the ThinkVantage suite to create both a recovery disk and also copies of the install disks. Both operations failed with "an internal error has caused this process to fail."
    Suggestions for debugging/fixing this appreciated.
    Thanks.
    Bob
  2. optomos
    optomos Notebook Evangelist
    Call Lenovo and tell them that it failed and your requesting they send you the recovery disks.
  3. TPA
    TPA Notebook Evangelist
    That very thing happened to me. I called support and told them it failed and they sent me the recovery disks for free, and overnighted them for free also. Make sure to call support and not customer service (the number you use to order a new computer.)
  4. bsodder
    bsodder Notebook Evangelist
    Are you sure that the CD/DVD burner is working? and was it selected as the destination?
  5. bobfff
    bobfff Newbie
    Called tech support and they're sending CDs. However, I would like to know why this doesn't work. It appears to be an issue experienced by others but the support tech had no suggestions.
    Thanks for the replies.
    Regards,
    Bob
  6. Arki
    Arki Super Moderator
    You must've had a fault recovery partition.
  7. gamemint
    gamemint Notebook Evangelist
    are all the recovery cd's the same or are they specific to your machine
  8. Arki
    Specific to your machine I believe. Or else you'd be able to install it on any machine.
