Crazy Mouse
Discussion in 'Windows OS and Software' started by pmassey31545, May 11, 2012.
  1. pmassey31545
    pmassey31545 Whats the mission sir?
    Can anyone tell me why my mouse cursor goes crazy when trying to open .txt files? If I double click to open it with the default text viewer that comes with Windows, the cursor starts flashing repeatedly and the blue 'busy' circle will flash and alternate between the 2 very fast.
    If I right click the file and choose edit, it opens fine. If I open with MS Word it opens fine. But if I ever try with the stock viewer, it will go crazy. In order to get it to stop, I must reboot, kill explorer.exe in task manager, or copy the file and delete the one I tried to open. If I delete the file then it clears up but an Explorer window opens.
    I'm lost and have searched here and of course Google/Bing! Any ideas???:confused:
  2. JOSEA
    JOSEA NONE
  3. pmassey31545
    Haven't tried any of that honestly. Will check.............
  4. pmassey31545
    OK. I have narrowed it down to something that I don't really know how to fix. I ran the disk scan and no bad system files. Ran a virus scan and nothing. Created a new account as suggested and the issue does not persist.
    So I look at my file extension associations and .txt doesn't exist at all-like it is missing. In the 'New account". it was there and associated with notepad. In my account, it is trying to open with explorer.exe for some reason and I don't know how to change it. Anyone?????????
  5. pmassey31545
    And 5 minutes after I wrote this I dug into the registry and found my problem. Somehow there was a UserChoice under file extensions for .txt files and it was explorer.exe that was trying to open. I knew that, just didn't know why and now I do.
    .txt also shows now in my file extensions list. I have no idea how it changed, but I probably did it somewhere along the way.
