CPU heatsink pressure - Razer 15 2018 ?
Discussion in 'Razer' started by sarou, Jul 15, 2018.
  1. sarou
    sarou Notebook Consultant
    Do you have any problem of heatsink pressure on cpu die or not ?
  2. raiden87
    raiden87 Notebook Evangelist
    I had. I have put a 0.5mm shim between die and hs and my temps went down by at least 10c
    hfm and VonCrisp like this.
  3. sarou
    Thank you for tour answer. I will try 2 graphite pads 0,2 +0,2 tais afternoon.
    Arondight and VonCrisp like this.
  4. sarou
    It s very strange. I have good pression on gpu. I gain 5c with screws exchange. But cpu is over 92c in cpu test of 3dmarks. LM + graphite pad.
    I will buy copper 0,5mm and 0,2mm for test.
    Arondight likes this.
  5. VonCrisp
    VonCrisp Notebook Evangelist
    Which graphite pad did you end up going for ? Would be good to get more info as the IC Graphite thread varies between so many different results.
    Can't wait for copper results. Maybe the graphite shims were too thin?
  6. hfm
    hfm Notebook Virtuoso
    What TIM?
  7. raiden87
    Lm on everything
    hfm likes this.
  8. sarou
    I would prefer graphite pad than LM for tests.
  9. sarou
    Panasonic soft-PGS
  10. rinneh
    rinneh Notebook Prophet
    becareful with graphete, they are electronically conductive. I do not recommend them to use those on stuff like VRM's or memory chips.
