CPU clock speed is stuck at 1.69 ghz
Discussion in 'Samsung' started by fxfxfx, May 3, 2018.
  1. fxfxfx
    fxfxfx Newbie
    Hello everyone, I have a Samsung np900x4d and when it is not plugged in, it's cpu clock speed is stuck at 1.69 ghz. When plugged in, it can go up to 2.40 ghz. I don't want to use it plugged all the time and performance difference is very annoying. Power plan doesn't change anything. The cpu is intel i5 3317u.
    Any help?
  2. Danishblunt
    Danishblunt Guest
    Its a power saving feature which limits the clockspeeds and opwer consumption to persever batterylife, if you would force the system to run at full speed you would drasticly decrease your batterylife. I would reocmmend leaving it as is.
  3. fxfxfx
    fxfxfx Newbie
    How do i disable that feature?
