CPU Bottleneck & CPU Cooling Dilemma
Discussion in 'MSI' started by ronferri, Jul 18, 2019.
  1. yrekabakery
    yrekabakery Notebook Virtuoso
    How would you OC the 6700HQ aside from BCLK?
  2. Papusan
    Slow monitoring software polling can show all cores running higher than default at same time. But it won’t run higher bin on all cores in load. It’s locked down as Fort Knox!
    yrekabakery likes this.
  3. TheQuentincc
    TheQuentincc Notebook Evangelist
    you simply use throttlestop and push the multiplier, thats what I did with my 6820HQ but yeah I didn't checked but the 6700hq is really locked unlike the 6820hq and older haswell (which allow +200MHz on 47xx series and +400MHz on 48xx and 49xx series), so my bad :)
    He can still undervolt it and avoid some throttling issue in some case if the cpu draw more than 45w at stock voltage, that's what happened with my 6820hq which will draw more than 45w in load at stock voltage and drop to 2.8GHz instead of 3.2GHz in 8 thread load, it might be due to the dell very restrictive power management
  4. Papusan
    All good bro. Yeah locked as a +100 years old virgin (6th and 7t gen low entry Hq the same):)
    Low end Haswell Mobile (4th gen) https://hwbot.org/hardware/processor/core_i7_4700mq/
