[Copper mod] Need some help. :/
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Undertaxxx, Jul 13, 2009.
  1. Undertaxxx
    Undertaxxx Notebook Consultant
    Hi,
    I'm going to (try) apply a thin copper sheet between my gpu and heatsink, the so called 'copper-mod'.
    Now i ordered 2 copper sheets, and they are wayyy to big so i need to cut them down to... well i don't know yet, maybe like 15mmx15mm
    Right now they are 10 cm x 10 cm.. how can i cut these things?
    Grtz
  2. moral hazard
    with metal cutting sheers
    Edit: use a deburring tool on the freshly cut edges. (not needed really but it will be more safe).
  3. Undertaxxx
    okay thank you, where can i pick these up?
    Could i maybe let them cut somewhere by a proffesional? (lol)
  4. moral hazard
    local hardware store maybe?
    Also I think I misspeled it, probably spelled shears.
    Just take one sheet to show someone at the hardware store and they should help you find the right tool.
  5. K-TRON
    K-TRON Hi, I'm Jimmy Diesel ^_^
    You can use Tin Snips or metal shears.
    You can use a file, or fine sandpaper to remove any burrs.
    If you find that the metal is not flat after a cut, you can do one of two things:
    1) If you have lapping stones, throw down 600 grit lapping powder and place the copper piece on the lower block. Put the upper block on and continue until the surface is a continuous color. Shiny marks indicate peaks in the piece. Continue until the piece is flat
    2) if you really just want to get it flat quick, use a ballpeen hammer and flatten it out. Only use a hard flat surface, if you use this method
    K-TRON
  6. Undertaxxx
    Also: how thick should the plate be, the one i have now is 1.5mm thick
  7. mattmcss
    mattmcss Notebook Deity
    Seems a little thick to be doing intricate cutting with metal shears, get yourself a hack saw and clamp that thing in a vise (wrapped in a towel to prevent damage to the copper).
  8. Mastershroom
    Mastershroom wat
    1 to 1.5mm thick is ideal for a GPU/heatsink copper mod. The one I'm using right now, thanks to K-TRON, is 14x14x1mm.
  9. mattmcss
    What did you use to cut yours?
    Or didn't you have to do any cutting?
  10. Mastershroom
    Mastershroom wat
    No, I got mine from K-TRON already in that size. He's probably got a few more for sale, ask him.
