Coollaboratory Liquid Ultra 100% Metal Thermal Interface on CPU, IC Diamond on GPU
Discussion in 'Gaming (Software and Graphics Cards)' started by Midas Touch, Jul 11, 2017.
  1. Midas Touch
    Midas Touch BGA Loving Enthusiast
  2. Vasudev
    Vasudev Notebook Prophet
    Move to Norway to @Papusan house. He has a secret lab for testing CPU/GPU temp. limits. Just kidding. Did you see his idle CPU temps are under 20C, so that means his PC can be OC'ed muvh higher w/o throttling.
    Midas Touch likes this.
  3. Midas Touch
    Clevo just got a better cooling solution...ok nice. I was kind of hoping that I will have the same temp. as in the guide...Alienware units seems to have a problematic heatsink but still manage to reach down to 30-40C.
    Vasudev likes this.
  4. Papusan
    Papusan BGABOOKS = That sucks!! STAHP! Dont buy FILTH...
    Perhaps clock down a few notches, from what allered run. Lower clock speed will provide lower temp:oops:
    Vasudev likes this.
  5. Vasudev
    Like I said earlier, @Papusan has room temps of below 20C all the time.
    @Midas Touch: What's your ambient temp?
  6. Midas Touch
    Lowest is probably 896.7 Mhz and idle temp at around 50-55C
    Sadly I don't have the device to measure ambient temp. :(
  7. Vasudev
    Even I don't have it, check local weather temp, add some 1-3 degress.
  8. Midas Touch
    It says 31C added 3C = 34C
  9. Vasudev
    Then its great temps. Mine too hits 92C on stock fan from AW. No need to worry. Your PC temps will be <85C peak usage.
    Also, every rise in 1C of room temp will increase cpu temps by 2-5C.
  10. Midas Touch
    I'm running Cinebench now...will get back in a moment.
    @Vasudev @Papusan I know it's not impressive with a BGA filth system.
    Crashed @42x :/
    Result @41x
    Is it possible to undervolt a 6820HK and overclock it at the same time?
