Coollaboratory Liquid Ultra 100% Metal Thermal Interface on CPU, IC Diamond on GPU
Discussion in 'Gaming (Software and Graphics Cards)' started by Midas Touch, Jul 11, 2017.
  1. MahmoudDewy
    MahmoudDewy Gaming Laptops Master Race!
    Finally someone came out and said it. I always believe the whole high performance expensive pads are completely unnecessary and go for cheap but highly compressible pads. Never had a problem!
  2. hmscott
    Having trouble saying the "F" word? ;)
    Fujipoly, and what's the point? Is Alphacool too expensive in comparison?
    Papusan likes this.
  3. Papusan
    Papusan JOKEBOOKS = That sucks! Dont wast your $$ on FILTH
    FujiPoly don't want push for 14w/mk in its own name. They will make more money on their more expensive 17w/mk pads!! Their websites is miss leading. And the options find it and buying it on the web is small. Why should they advertise cheaper but better products as their 14w/mk?
    Components on laptop MB outside the cpu/gpu core haven't temp reading sensors. Even pch chips on some MB wouldn't show the temp.
  4. Vasudev
    Vasudev Notebook Prophet
    I'll look into @Mr. Fox , @Papusan opinions and get what's available here. Maybe I'll scout the city for some thermal pads. Problem is, I don't have vernier calipers for enhanced precision down to mm.
    Papusan and Mr. Fox like this.
  5. Mr. Fox
    I have the BIOS configured on the P870 to boot and run the 7700K at 5.2GHz with c-states disabled. Yes, I can actually use it like this with the right cooling tweaks in place. Here were the overnight idle temperatures. I stopped using it at 8:30 PM and got up at 3:30 AM. When I walked up to it and set down to start using it at 4:00 AM, here is what HWiNFO64 showed.
    And, after 3.5 hours of doing "normal" stuff like web browsing, email, etc. the temps are still fine at 5.2GHz. Overkill? Sure, totally. But, I can so I don't see any reason not to. The fans are on autopilot and they've not ramped up in speed or been audible since I began using the machine at 4:00 AM.
    TBoneSan, Papusan and Vasudev like this.
  6. Mr. Fox
    So, I went ahead and used Conductonaut on my 1080 SLI setup and cut some nifty foam barriers to keep it from leaking out onto other stuff. I have Kapton tape covering the GPU components around the die, then put one drop of super glue on each side of the die to hold the foam in place on the Kapton tape. The foam is 1/8th inch and easily compressible so as to not interfere with heat sink to die contact. Temps turned out pretty nice. Never dropped below 1911 on core with the @Prema beta vBIOS. Nice compliment to the Bitspower IHS lap job.
  7. Midas Touch
    Midas Touch BGA Loving Enthusiast
    Don't be modest Mr. Fox, you can always share your videos with us.
    I like this idea than electrical tape, electrical tape looks primitive.
    hmscott, Papusan and Vasudev like this.
  8. HTWingNut
    HTWingNut Potato
    I find this is a good way to cool your computer.
  9. Vasudev
    The guy simply wastes food just for fun, if you watch his other videos in the channel.
  10. HTWingNut
    HTWingNut Potato
    Small price to pay to make hundreds of thousands of dollars... :p
    Vasudev likes this.
