Coollaboratory Liquid Ultra 100% Metal Thermal Interface on CPU, IC Diamond on GPU
Discussion in 'Gaming (Software and Graphics Cards)' started by Midas Touch, Jul 11, 2017.
  1. Midas Touch
    Midas Touch BGA Loving Enthusiast
    I saw this in HIDevolution customization option so I ordered Coollaboratory Liquid Ultra and IC Diamond...I was wondering if I can do the application for my MSI GT80 as Coollaboratory Liquid for the 6820HK and IC Diamond on both the 980m's?
  2. MahmoudDewy
    MahmoudDewy Gaming Laptops Master Race!
    I don't see why not :D I am running CLU on my CPU and Noctua on my GPU and I am pretty happy with the temps.
    But you really need to take care when applying liquid metal. There is a thread in Alienware subsection under new AW machines section.
    Check it out.
    Vasudev and Midas Touch like this.
  3. Midas Touch
    Thank you for the very quick response...I was kinda of hoping if you can point me out to the right direction good sir. I'm also watching this:
  4. MahmoudDewy
    Midas Touch likes this.
  5. Midas Touch
    Already dismantled...haha, just needed for a proper application...is my first time using 2 different paste on this machine.
    Also should leave the electrical tape there after repasting?
    Also I currently don't have that 33+ tape....I have some random black electrical tape right now tho...it says it can withstand up to 80C.
    http://www.magnaprime.com.ph/contact/17-products/max-tapes/8-max-electrical-tape/
    Not sure if I use this since it it can stand up to 80C only...
    EDIT:
    I guess I'll just leave everything open for now and going to get a good tape in the morning...
    Vasudev likes this.
  6. Vasudev
    Vasudev Notebook Prophet
    Try a tape that can withstand upto 100-105C similar to scotch super 33.
  7. Midas Touch
    Haha...you're right man...I can't leave this cheapo tape the chance to potentially jeopardize this whole operation xD
    I will get a good electrical tape in the morning...I wasn't aware that CLU application requires tape. :/
    Vasudev likes this.
  8. Vasudev
  9. MahmoudDewy
    If the tape is rated for 80C it may melt if your machine overheats for any reason. Also, the tape does stay after the application.
    Midas Touch and Vasudev like this.
  10. Midas Touch
    @Vasudev @MahmoudDewy
    I bought this today:
    http://imgur.com/a/dUZj8
    Same brand in the guide...but if you take a closer look the instructions at the back it says not more than 80C....does this mean I bought a fake tape?
