Connecting to a TV?
Discussion in 'Apple and Mac OS X' started by Duster73, Aug 6, 2010.
  1. Duster73
    Duster73 Notebook Consultant
    Is it possible to connect my MBP 13 to a TV or another monitor if I want to watch movies or something? Or is the apple cinema display my only option?
  2. Underpantman
    Underpantman Notebook Virtuoso
    Yes it's possible !
    You will need an adapter... A mini display to what ever your TV can except. Eg dvi, vga or hdmi. The official apple ones are a bit pricey but there are lots of 3rd party ones that work just as well for much less.
    A
  3. snork
    snork Notebook Evangelist
    It also depends if you have the original 2009 MBP 13 or updated 2010 model. The 2010 models can also output audio from the mini-display port so if you go to HDMI you just need a simple adapter cable. If you have a 2009 model and want HDMI output you will either need a separate cable for the audio or get a mini-display port to HDMI plus USB or optical audio cable adapter.
