Connect D620 to TV
Discussion in 'Dell' started by Amateur, Jul 17, 2006.
  1. Amateur
    Amateur Notebook Consultant
    Is it possinle to connect the Dell Latitude D620 a tv using the tv as the monitor?
  2. Charles P. Jefferies
    Charles P. Jefferies TG Lead Moderator Super Moderator
    Yes, it is possible. Unfortunately, the D620 lacks an S-video port, but it does have VGA, so you would have to find an VGA > S-video adapter or similar.
    Not sure you would want to use the TV as a monitor though . . it will be blurrier than your laptop's monitor. Depends on what kind of TV you have though.
  3. Amateur
    Not only for a monitor but also to play DVD's on the laptop and watch them on the tv. That possible?
  4. Charles P. Jefferies
    Yes, you can switch over to the TV by using the Fn keys . . I don't have a Dell, but check your users manual. One of the F4, F5, etc keys will have a little blue monitor label on it - hit Fn + that key to switch over to the TV, then hit it again to make it primary.
  5. Amateur
    Cheers, thanks.
  6. cd0207
    cd0207 Newbie
    Get a D/Dock from ebay for $60 which has S-video, DVI and more
  7. Epsi
    Epsi Notebook Enthusiast
    The easiest way is to get a D/Dock and use an S-Video cable, or an S-Video to composite cable if, like me, you have an older TV that doesn't have S-Video in.
