Comparing 9750H vs i7 U series for use on battery
Discussion in 'What Notebook Should I Buy?' started by CocoLoco, Jan 1, 2020.
  1. CocoLoco
    CocoLoco Notebook Guru
    I mostly use laptop for writing and compiling code on battery. In the fall, I got an Aero 17 and have been really disappointed with power on battery, throttling, etc. Makes me wonder if an H series has any speed advantages at all on battery over U series i7s -- given how much they are throttled.
    Does anyone have any insight on this? Ever see any comparisons?
  2. Charles P. Jefferies
    Assuming proper cooling (which is not an assumption to make these days), an H-series chip will have a massive performance advantage over a U-series for tasks that require lots of CPU power, like rendering/encoding, as the clockspeeds won't fall off as drastically in the long run. My experience is that the U-series chips will throttle down to their base clock speeds in long-running tasks, while the H-series chips should stay closer to their maximum Turbo Boost clocks.
    Did you repaste your notebook? Also undervolt it with ThrottleStop. You can get a lot more performance out of your notebook doing both. Undervolting can especially help with battery life and will reduce heat.
    Charles
  3. CocoLoco
    The problem is not cooling. Problem is laptop makers throttling H CPUs on battery irrespective of temperature.
