Compaq Presario C700 Upgrades And Facts!
Discussion in 'HP' started by drmega0226, Apr 4, 2008.
  1. jeremy3d
    jeremy3d Newbie
    thanks but when it comes to gaming it sucks but with a few tweaks itll be a semi beast :D.
    has anyone tried using different keyboard on their laptop ? because i was thinking ofreplacing this c762nr keyboard into dv3500 keyboard will that work ? provided that it has the same connector.
  2. orestian
    orestian Newbie
    In that case try reading that
    http://forum.notebookreview.com/gaming-software-graphics-cards/418851-diy-egpu-experiences.html
    Why you want to replace the keyboard? There is not much difference
  3. jeremy3d
    jeremy3d Newbie
    ohhh im so gonna try that thanks a bunch for the link but downside is your gonna sacrifice your wifi card just for it but oh well it worth the fps i can use a usb wifi thingy anyway.
    because i want to have a backlit keyboard so if it will work then i will just have to solder it to a usb port to power the backlit.
  4. orestian
    orestian Newbie
    Hope you get things shorted... Let me know about your progress, on both eGPU and keyboard
  5. jeremy3d
    jeremy3d Newbie
    sorry.
    ill be sure to update you guys.i dont have spare keyboard here to test btw i need to ebay first :/
  6. orestian
    orestian Newbie
  7. jeremy3d
    jeremy3d Newbie
    i need to compare the connection if this one will fit before i try buying it , help will be gladly appreciate.
    the second one it use to power the backlit unfornately there is no connector on this board or model but i can solder it to a nearby usb port just like the guide here http://forum.notebookreview.com/asus/465841-ul30-backlit-keyboard-mod.html
  8. dotcolin
    dotcolin Newbie
    Does anyone know If I upgrade to windows 7 64 bit version, can I then upgrade my Ram to 4gb? I read that on 32 bit windows only 2 or 3gb can be recognized - is that a limitation of the OS or the motherboard?
    Thanks!
  9. jeremy3d
    jeremy3d Newbie
    hi dotclin
    if you're using a gl960 chipset, it dosent work, whatever you do it will still bsod. but ive heard using a single 4gb module does the fix. yes its a limitation google 32bit if u want to learn more. oh and the gl960 chipset it has a max of 2gb but unofficial 3gb if u put 2gb and 1gb combo.
  10. ksmr90
    ksmr90 Newbie
    i've compaq c770tu laptop with intel t2370 processor, the project i'm going to work on requires VT (virtualization support).
    to which processor should i upgrade to?, do i have to replace the motherboard too? how much is it going to cost me?
    kindly help me out
