Companion to my 17-inch MacBook Pro
Discussion in 'What Notebook Should I Buy?' started by Datamonger, Feb 12, 2013.
  1. Datamonger
    Datamonger Notebook Evangelist
    General Questions
    1) What is your budget?
    As cheap as possible.
    a. Netbook; 10” screen or less
    b. Ultraportable; 11" - 12” screen
    c. Thin and Light; 13" - 14" screen
    Online, United States
    a. Like: Apple, Dell (business products), Toshiba, IBM/Lenovo
    b. Dislike: HP, Dell (consumer products), Acer and its sub-brands
    Yes
    General use.
    To and from school, when I resume taking classes
    No
    At least 3
    Either/or
    11) What OS do you prefer? Windows (XP or Vista or Windows 7), Mac OS, Linux, etc.
    If it's not Linux, then it's OK!
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. Click here for Screen resolution information.
    Doesn't really matter to me, but higher is preferred
    13) Do you want a Glossy/reflective screen or a Matte/non-glossy screen?
    Matte
    Build Quality and Design
    No
    Within a few days to a few months
    At least 2 years
    Notebook Components
    Not really important as I have extra high-capacity drives. SSD would be nice, but is not necessary
    No optical drive is needed.
    I'm basically looking for a low-cost companion to my MacBook Pro. Nothing fancy, just something a little more portable than my 17-inch beast.
  2. KCETech1
    KCETech1 Notebook Prophet
    not sure if you would call it low cost ... you never specified budget but my favorite is the X230 for its battery life and storage ability... and about 20% faster than your 17" on the CPU
  3. Datamonger
    I actually wouldn't mind having an X230. But yeah, definitely a bit too much. By the way, are you using an MCE OptiBay in your 17-inch MBP or Other World Computing Data Doubler? I picked up a cheap eBay optibay and it doesn't work.
  4. KCETech1
    in using a decent optibay adaptor from a thinkpad actually. OWC's offerings never excited me too much normally. as for the e-bay one it should work as long as your sata connections are good, its a standard interface the only fun is the fact we're dealing with a slotload and dont have a tray opening.
