Compact E-ATX case recommendations, no light pollutions.
Discussion in 'Desktop Hardware' started by RMSMajestic, Feb 18, 2019.
  1. RMSMajestic
    RMSMajestic Notebook Consultant
    As described in the title. I'm currently looking for a compact case that can take E-ATX Dual CPU motherboards.
    Preferrably no light pollution (RBG/side panel/ same ****).
    Preferrably as many ventilation holes.
    Preferrably as customizable as possible.
    PSU at the bottom!
    Corsair 400C looks a bit ugly to me..... Also the build quality isn't that great
    CoolerMaster MasterBox Pro 5 System Builder Edition seems to be closest to my requirement. But are nowhere to be found here in US.....
    Any recommendations?
  2. Convel
    Convel Notebook Deity
    The Phanteks Eclipse P600S and Fractal Design R6 USB-C are two mid-tower E-ATX cases that can be had without a glass panel and obnoxious lighting effects. Don't have first-hand experience with either, but I did come away impressed with the value proposition of an older R-series Fractal case when I did a build in it for someone else.
  3. RMSMajestic
    FD R6 is a bit too big...... looks like I might need to get a Cooler master Pro 5 from GB :/
  4. Convel
    The CM Pro 5 is a larger case than the R6. 512 x 235 x 548 mm = 65.9 L V.S. 543 x 233 x 465 mm = 58.8 L. There are of course smaller E-ATX cases than the three mentioned so far, one example being the 45.9L SilentiumPC Armis AR5X, but most recent cases have several tempered glass sides, RGB, or both.
    One slightly more heartfelt recommendation: the Lian-Li PC-O12. Yes, it has one too many tempered glass sides, but it has ample ventilation still, and more importantly: quality aluminium construction and minimalist RGB-free design. It's a 56.7 L case.
  5. RMSMajestic
    I mean the Masterbox pro 5 , not master case pro 5. the size is 500 x 223 x 475.
    https://www.amazon.com/Cooler-Maste...erbox+5&qid=1551300171&s=gateway&sr=8-11&th=1
    https://www.newegg.com/Product/Prod...&cm_re=masterbox_5-_-9SIA6ZP8MM8544-_-Product
    Lian-Li PC-O12 looks tempting though. Only thing is that it has too many panels.
    *sigh* shouldn't have hesitated to get some cases few years back.
  6. Convel
  7. RMSMajestic
    *sigh* I think that case is nowhere accessible here in USA.
    Thinkstation P700 case kinda better fit my taste. but it has a weird shape motherboard and being impossible to upgrade from a barebone :/
  8. RMSMajestic
  9. Convel
    Can't think of a case that's similar to those SilverStones while being vertical, I'm afraid. A couple of additional suggestions: the DeepCool MATREXX 55 MESH and E-SHIELD. Both of them have a TG panel, but they're compact E-ATX cases. There's also the Thermaltake Suppressor F51, and while it certainly isn't blinged out, it's bigger and less modern that the Fractal Design Define R6.
  10. jeremyshaw
    jeremyshaw Big time Idiot
    Convel likes this.
