command center problem.
Discussion in 'Alienware 17 and M17x' started by pinoy_92, Mar 14, 2013.
  1. pinoy_92
    pinoy_92 Notebook Evangelist
    i recently did a fresh install of win7 and now all the led lighting on my laptop is not working. i installed the microsoft .net framework then osd then command center. the osd and command center were taken directly from dell's website. everything seems to be working fine but the led light does not light up. during start up i keep getting an error message from .net framework and command center. can anyone help me please.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at AlienLabs.AlienFX.Controller.LightsZoneController.SupportChangeBrightness()
    at AlienLabs.AlienFX.Controller.ControllerMainForm.configureTrayIconContextMenu()
    at AlienLabs.AlienFX.Controller.ControllerMainForm.initializeTrayIcon()
    at AlienLabs.AlienFX.Controller.ControllerMainForm.controllerMainFormLoad(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ContainerControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at AlienLabs.AlienFX.Controller.ControllerMainForm.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    AlienwareAlienFXController
    Assembly Version: 1.0.92.0
    Win32 Version: 1.0.92.0
    CodeBase: file:///C:/Program%20Files/Alienware/Command%20Center/AlienwareAlienFXController.exe
    AlienwareAlienFXTools
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/AlienwareAlienFXTools/1.0.92.0__bebb3c8816410241/AlienwareAlienFXTools.dll
    Alienlabs.CommandCenter.Tools
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Alienlabs.CommandCenter.Tools/1.0.92.0__bebb3c8816410241/Alienlabs.CommandCenter.Tools.dll
    Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    AlienLabsTools
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/AlienLabsTools/1.0.92.0__bebb3c8816410241/AlienLabsTools.dll
    System.Configuration
    Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    WindowsBase
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.6920.5448 built by: Win7SP1GDR
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
    PresentationFramework
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
    PresentationCore
    CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
    System.Management
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    AlienFX.DeviceDiscovery
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/AlienFX.DeviceDiscovery/1.0.92.0__bebb3c8816410241/AlienFX.DeviceDiscovery.dll
    AlienLabs.MasterIOBoard.Communication.Core
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/AlienLabs.MasterIOBoard.Communication.Core/1.0.92.0__bebb3c8816410241/AlienLabs.MasterIOBoard.Communication.Core.dll
    AlienFX.Communication
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/AlienFX.Communication/1.0.92.0__bebb3c8816410241/AlienFX.Communication.dll
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/AlienLabs.MasterIOBoard.Communication/1.0.92.0__bebb3c8816410241/AlienLabs.MasterIOBoard.Communication.dll
    System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.5420 built by: Win7SP1
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
    LightFX
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/LightFX/1.0.92.0__bebb3c8816410241/LightFX.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  2. pinoy_92
    can anyone help me out?
