Clevo W740SU 14.1"
Discussion in 'Sager and Clevo' started by tommytomatoe, Jun 16, 2013.
  1. Support.1@XOTIC PC
    Support.1@XOTIC PC Company Representative
    Have you checked in the power settings in the control panel? In the advanced power settings for the power mode you are on, you can set the maximum CPU usage for when it is on battery. I would make sure it is set to 100% in there.
  2. kaltmond
    kaltmond Clepple
    Same problem before, i think it's a bios problem. compatibility.
  3. Quicklite
    Quicklite Notebook Deity
    Hey guys
    slightly stuck by the battery throttles (1.3Ghz max on battery) issue - sort of defeats the point of a 14.1 body if it can't be used fully on battery.
    has anyone came across a bios mod / etc that fixes the throttles issue whilst on battery?
  4. bernex
    bernex Notebook Enthusiast
    My accumulator is swelled.
    Were are I can buy new one?(out of stock in ebay and aliexpress). Or find accumulator items(cells)?
  5. yaw360
    yaw360 Newbie
    Try this tool and turn on options below (perhaps some don't really need)
    http://kawamoto.no-ip.org/henteko/myapp_en.html#ditherig
    • Fix to the highest
    • Fix CPU frequencies at the nominal value
    • Disable BD PROCHOT signal
    • Disable Running Average Power Limit
