Clevo W650sj desktop cooler ? tips for my project please!
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by edney helene, Nov 25, 2018.
Tags:
  1. senso
    senso Notebook Deity
    Install/download Intel XTU or ThrottleStop, play around with undervolting, its free.
    If you just remove the bottom cover and raise the back of the laptop it will run cooler, if you put into a suitcase with bigger heatsinks without fans to move the air around/in/out the case it will heat up just the same.
  2. edney helene
    edney helene Notebook Geek
    Its already using an support and already lifted up, the idea is to use coolers not only heatsink.
    To fix it i would have to buy from other country the heatsink and also the case from a dead one to fix all problems i have with it, trust me, its just cheaper and easier to build it inside a briefcase with new heatsinks.
  3. edney helene
    Fixed it by making an custom cooler solution...thanks anyways.
  4. Rengsey R. H. Jr.
    Do you have a picture of what you have done to help some the heat issue?
