Clevo W650KK1 Cooling System? Reviews?
Discussion in 'Sager and Clevo' started by sicily428, Mar 11, 2017.
  1. blacklord049
    blacklord049 Notebook Enthusiast
  2. AndiiiHD
    AndiiiHD Notebook Consultant
    just wanted to ask the same :-D, had asked my dealer and got Bios 1.08 but EC 1.07 was missing. They are checking if its possible to get it....
  3. Meaker@Sager
    They should be able to go back to Clevo if they don't.
  4. kalyway
    kalyway Newbie
    I've gone through every page trying to find out more about this laptop, W650KK1. I am definitely impressed for this price. I decided to stick with 8GB 2400 DDR4 SODIMM RAM and an i5-7500T so I can get pretty good performance along with pretty good battery life. I think with a regular CPU I would probably have gotten 4-6hrs of battery life, so I'm hoping this lower powered T version will help gain even more battery life.
    Though I may just sell of the 7500T and get a regular desktop i5 7500 and downvolt so get more battery life. We'll see! I'm waiting for the CPU so hope to get it here soon!
    sicily428 likes this.
  5. Meaker@Sager
    It comes down to the allowed TDP and voltage. With the same limits the chips would be the same (with only silicon lottery differences).
  6. xyamerican
    xyamerican Newbie
    appreciate your efforts. Has anyone been able to get this to output 100+hz to an external screen? It's HDMI 1.0 right? so we can't
  7. Meaker@Sager
    The display ports will be able to output to high refresh rate monitors.
  8. MageTank
    MageTank Notebook Consultant
    I don't believe the W650KK1 has Displayport. I don't see one on my unit, unless they came out with a different revision.
    I can try the HDMI port to see exactly what the limitation is. I have a few high refresh rate monitors of varying resolutions that support HDMI, so I'll try to get that information for you soon.
  9. kalyway
    kalyway Newbie
    Mine doesn't have a display port either. Just HDMI and VGA.
  10. AndiiiHD
    i think he meant the internal eDP connection (which is a displayport)
