Clevo W650KK1 Cooling System? Reviews?
Discussion in 'Sager and Clevo' started by sicily428, Mar 11, 2017.
  1. DuongTHVN
    DuongTHVN Notebook Guru
    Dear guy!
    Please, i have seen 2 m.2 Slot, can i install NVME PCIex SSD on that?
    Thanks
  2. Meaker@Sager
    Check the specifications at the end of your user manual for exact slot specifications.
    DuongTHVN likes this.
  3. DuongTHVN
    Thanks
    but where can i to get it ?
    i have research but no link for download :(
  4. Meaker@Sager
    You should have got a manual with it.
  5. xyamerican
    xyamerican Newbie
    I just installed the 120hz screen you suggested and it turned on okay and was auto set to 120hz, but my brightness will not change from max. Any input? was hoping it would just work like yours did after reading your post here. H/W:0A F/W:1 is also written on the back. mind comparing with the one amazon sent you? (i used the link you posted for the b156htn05.2, hardware ID in windows is AUO52ed
    i did read of a method a user called 'hot swapping' (which other users said was dangerous so maybe do not attempt) your screens. meaning, have the computer running with the non brightness bugged screen in when you do the swap to the new one. I'm going to call eluktronics in the morning asking about swapping the keyboard to a backlit, and if they can help with my panel issue. maybe with a bios update. this screen is used in another of their models, one which starts with a P i believe
  6. sicily428
    sicily428 Donuts!! :)
    hi @52571abc !
    do you think a coffee lake could be possible also for this w650?
  7. 52571abc
    52571abc Notebook Consultant
    send me bios ,then I can get
    the job done maybe I can make it support skylake es processor
  8. DuongTHVN
    anyway for P775DM3-G :)
  9. 52571abc
  10. sicily428
