Clevo W650KK1 Cooling System? Reviews?
Discussion in 'Sager and Clevo' started by sicily428, Mar 11, 2017.
  1. cannabis4711
    cannabis4711 Newbie
    Dies the W650KK1 have different cooling systems or is it always the same? Is the cooling syste strong enough for the 6600k or are the temperatures too high? Is it possible to undervolt the 6600k if the temperatures are too high?
  2. Meaker@Sager
    The CPU cooling system is identical in all units.
    cannabis4711 likes this.
  3. sicily428
    sicily428 Donuts!! :)
    that cpu needs to be delidded
  4. cannabis4711
    cannabis4711 Newbie
    Oh okay, thank you. Why do I need to remove the lid? oO (Why) Doesn't it work with the lid? Is that procedure difficult? oO
    Thanks a lot.
  5. sicily428
    thats K cpu has a TDP of 91W and a really bad thermal compound so you need to delid and repaste
  6. cannabis4711
    cannabis4711 Newbie
    Okay thanks a lot. After that I need to reapply the head spreader, or? Thank you again.
  7. sicily428
    you are welcome!
  8. blacklord049
    blacklord049 Notebook Enthusiast
    Latest Intel HD Graphics drivers (23.20.16.4944) on my configuration disable the fn + F8 and F9 keys to adjust brightness
  9. MageTank
    MageTank Notebook Consultant
    I would say a 6600k would work fine after a delid. You can undervolt the CPU using XTU, and likely maintain full boost under load. My 6600T when hitting a 3.3ghz all-core boost doesn't hit 50C under 48k FFT Prime95 with a -75mv undervolt.
    I'll take a look at that on my unit, have not tested the Intel iGPU driver in a while. Am honestly surprised my brightness control still works after swapping out to a 120hz panel, lol.
  10. AndiiiHD
    AndiiiHD Notebook Consultant
    i am really unsatisfied with my standard FullHD panel because its very very dark. Which exact panel model did you replace with which 120Hz model. And did you need a new cable ?
