Clevo vBIOS for Quadro p4200 going in P750DM-G
Discussion in 'Hardware Components and Aftermarket Upgrades' started by MKazmer, Sep 19, 2020.
  1. MKazmer
    MKazmer Notebook Consultant
    I purchased a Quadro P4200 to install in my Clevo P750DM-G. I believe it comes with the HP vBIOS. I do have a TL866II programmer and can program the vBIOS before installing it in the system if needed, but I'm curious if that will be necessary. I have done several mxm swaps and have no problem with it. The last one I did was a GTX1060 in this same machine.
    Advice on this will be appreciated.
    Thank you
  2. MKazmer
    I may have made a double post with this thread as well, and I apologize for that. If a moderators sees this, please delete it or join it if there is a duplicate post. I apologize for creating more work for you.
  3. MKazmer
    I ordered a chip from ebay that supposedly has the Clevo vBIOS for the Quadro p4200. I will post the results here once I get it all soldered up and installed.
  4. MKazmer
    I soldered on the vBIOS chip and installed the P4200 into the P750DM, however, when I installed the driver, the screen went blank for 5-10 minutes before coming back on scrambled, but mostly black. I have done this twice now with the same result. If someone can help me acquire a Dell vBIOS or other vBIOS known to work with Clevo, it would be greatly appreciated.
    I'm not sure what to do next here to get this working, any help or advice will be greatly appreciated.
  5. MKazmer
    The BIOS eeprom soldered on
    Version info from NVFlash
    GPU-z info
    Device Manager info
  6. MKazmer
    This P4200 Dell vBIOS resolved the problem. Drivers are now installed and it's up and running benchmarks now that I will post in a new thread.
    luisxd, thewizzard1 and mirage_bg like this.
  7. MKazmer
    The following image is what the artifacting looked like.
    mirage_bg likes this.
  8. mirage_bg
    mirage_bg Notebook Deity
    I am impatiently waiting for the benches!:)))
  9. MKazmer
    I was looking forward to it also. They are up in another thread. Do you know if thermal throttling on the CPU can inhibit GPU scores in the benchmarks? If so, the numbers could go up once I get the shim on the cpu side.
    Here is the link to the other thread with benchmarks
  10. Tobias1245
    Tobias1245 Notebook Enthusiast
    Hello MKazmer,
    this is good work. My plan is to build p4200 into zbook 17 G1. I have a problem with the vbios on my card. The chip that I have is a GigaDevice 25Q20BT with clevo bios. Nvflash64 and GPU-Z do not find the Bios. The eeprom ID is unknown to the Nvflash. I managed to apply the dellvbios with the programmer CH341A , but in the end this did not solve the problem.
    Have you any idea for this problem?
    What do you think about the GigaDevice 25Q20BT?
    Any Pictures with infos.
    Thank you for your answer.
