CLEVO P870TM1-G with problems
Discussion in 'Price Check Forum' started by luisxd, Sep 6, 2020.
  1. luisxd
    luisxd Notebook Consultant
    Updated post to sell it as barebones + GTX1080x2, what would be a good price to sell it?
    I´ve listed two options, with and without GPUs.
    OPTION 1
    GTX 1080 SLI (2xGTX1080)
    Vapor Chamber
    stock BIOS (not premaBIOS)
    2x 330w power adapter
    OPTION 2
    Vapor Chamber
    PROBLEMS
    LCD broken (needs a replacement)
    Few scuffs here and there on the chassis and some bezels broken (the thin ones from behind, not from the screen)
    PHOTOS (IMGUR)
  2. Reciever
    Reciever D! For Dragon!
    If the problems are unknown then parting it out may yield much more cash
  3. luisxd
    What do you mean by unknown?, I listed them
  4. Dr. AMK
    Dr. AMK Living with Hope
    LCD broken (needs a new one) > cost $100 ~ $150. The laptop should work just fine with an external screen, so did you test it?
    Few scuffs here and there on the chassis and some bezels broken (the thin ones from behind, not from the screen) > It will be nice that you share some pictures. and what caused this damage?
    Papusan and luisxd like this.
  5. luisxd
    I've been using it with an external monitor (Dell S2716DG) and it has worked great, I even used it with two monitors for a while (1440p and 2160p). I'll upload some photos later.
    Dr. AMK likes this.
  6. luisxd
    PHOTOS (IMGUR)
    Dr. AMK likes this.
  7. Dr. AMK
    luisxd likes this.
  8. luisxd
    Does it really looks that bad?
    Dr. AMK likes this.
  9. Dr. AMK
    Only from outside, not so bad to use at home. The housing can be found used or new if someone wants to replace it.
    luisxd likes this.
  10. electrosoft
    electrosoft Tick Tock Clarice....
    Do you have a photo of it opened up?
    luisxd likes this.
