Clevo P870TM1-G temperature limit
Discussion in 'Sager and Clevo' started by luisxd, Jul 26, 2020.
  1. luisxd
    luisxd Notebook Consultant
    Is there a way to set a temperature limit on a Clevo P870TM1-G (GTX 1080 x 2)?, MSI Afterburner doesn't show the option and RLECViewer doesn't work on every game for some reason.
    Thanks in advance.
  2. Dr. AMK
    Dr. AMK Living with Hope
    You need to do some undervolting to the CPU and GPU's, make sure you have a good thermal Past/Pads applied for both. And the Fan's curves should be aggressive using Overclocking option in the command center application. Using cooling pad is highly recommended.
    Good luck.
    luisxd likes this.
  3. luisxd
    I actually have done all of that but summer here has been very hot lately (115 F almost every day) and playing on 1440p in my new monitor is almost impossible due to temperatures, I reach 80C almost instantly in any game and it goes up to 88C in some of them (I have close it wen it gets this hot). I can't control anymore how the temperatures behave so I'd like to just put a limit on them, I don't care about FPS at this point lol.
    Thanks for the reply!
  4. Dr. AMK
    Check your vBios version, mine maximum temps are 80~82c in the full load. and make sure that the GPU's heatsink making a good contact,
  5. luisxd
    Mine says 91.0 C
  6. luisxd
  7. Aerokski
    Aerokski Notebook Enthusiast
    luisxd likes this.
  8. luisxd
    How did you unlock voltage control?
    Edit: NVm I just figured out I have to edit the curve just like in MSI AB :p
  9. Aerokski
    If you want to control your gpu by temperature limit don't undervolt. Just set specific throotling temperature for gpu for instance 78 degrees and set gpu overclock to around +100. When gpu will increase temperature it will throotle. Original nvidia voltage curve have small steps wich are helpful to maintain suitable clocks.
    luisxd and jc_denton like this.
  10. luisxd
    Thanks man, it really helped. I don't usually trust those gpu control software from AIBs, but this one from Asus worked great so far :)
    Aerokski likes this.
