clevo p870km1-g sound issues
Discussion in 'Sager and Clevo' started by paulofeg, May 26, 2019.
  1. paulofeg
    paulofeg Notebook Geek
    originally this sound issue only affected blu rays but now my speakers are loud no matter what. Here is the issue if i use speakers the volume nearly maxed which is incredibly loud and adjusting the sound via realtek and windows has no effect and remains loud, however if i switch to headphone adjusting sounds via the digital output works just fine. Its baffling maybe someone here can figure it out. no volume control works for speakers its equally loud no matter the setting.
      File size:
      284.4 KB
      65
      File size:
      822.9 KB
      57
      File size:
      294.3 KB
      44
  2. liosafe
    liosafe Notebook Enthusiast
    Hello delete Windows audio driver delete clevo audio driver or maybe you install mod audio driver delete. reinstall from clevo site.
    also if you make any change to unlock bios also reset to default, after when you install audio driver you can tweak it back
    Good luck
  3. artpra
    artpra Notebook Consultant
    Most probably it`s caused by updated Realtek drivers which somehow aren`t fully compatible. Did you updated them recently?
    Uninstall, reboot, install that supplied by the Clevo (old) or use that from before update.
