!Clevo P870km Problem with slave GPU and SLI!
Discussion in 'Sager and Clevo' started by kela777slk, Mar 17, 2019.
Tags:
  1. kela777slk
    kela777slk Notebook Consultant
    Contacts is clean. in master slot both GPUs working and recognize properly! 3dmark over 15000k points, furmark - ok. BGA chips is ok, maybe problem in sli iterface. I order secondary GPU heatsink and original SLI bridge...
    When I receive the package (1 month), I will try to install and check again two video cards.
    if not still working, this will mean that the problem is in the interface (incompatibility) of the video card or in the motherboard...
  2. DARCODER
    DARCODER Notebook Deity
    Did you simply try to put a mxm into slave slot alone (instead of master slot ) ?
    If it is working then its your cable.
  3. Meaker@Sager
    Master slot has to be populated.
  4. DaMafiaGamer
    DaMafiaGamer Notebook Deity
    @TheDantee had the same problem but for him the GPUs worked after a manual install. He uninstalled the driver using ddu and reinstalled them.
    Try this before considering anything being faulty.
  5. kela777slk
    hi!. I bought original new parts for my laptop. This is the SLI cable and the secondary heatsink. I installed it all. SLI settings not available to me. I tried the test program PhysX Fluid Mark and the second video card was loaded by 30%, the first by 70%. in the driver put PhysX load on the second video card. Thus, the video card works, but the SLI mode cannot be turned on, because not active in the nvidia control configuration.... i try install new operating system - Windows 10 and windows 7 - nothing change. no SLI in driver option...
    Maybe whose know patch nvidia driver for manualy enable SLI option?
  6. Prema
    Prema Your Freedom, Your Choice
    Flash stock BIOS and SLI will be magically fixed... ;)
    Papusan, kela777slk and DaMafiaGamer like this.
  7. DaMafiaGamer
    Yes a fix is coming though... In about 4-5 hours time :D
    Enjoying my holiday in Pakistan atm (a beautiful view on top of some mountains lol) so I’ll upload 9th Bioses at around 8pm here which is 4pm in the UK.
    BTW the heat and mosquito bites are killing me lol so it might take sometime. At least there’s better internet now.
    kela777slk likes this.
  8. kela777slk
    oh. ,Maybe a dream will be lucky to activate two video cards! i cannt flash stock bios because cpu is cofee lake - 8700, stock bios not support this cpu.
    how i can flash p870tm in my km board. maybe stock TM bios will fix this problem? flash need programmer or possible flashsing from USB flash drive?
