Clevo P870DM-G Power Issue #3
Discussion in 'Sager and Clevo' started by rockman1216, Nov 10, 2021.
  1. rockman1216
    rockman1216 Notebook Geek
    @Meaker@Sager @Donald@HIDevolution @EurocomTechspert @Johnksss@iBUYPOWER @Mr. Fox @Prema @Prostar Computer @XMG @Larry@LPC-Digital @Tanner@XoticPC @DaMafiaGamer
    So in a follow up to these two threads
    http://forum.notebookreview.com/threads/clevo-p870dm-g-power-issue-update-2.830992/
    http://forum.notebookreview.com/threads/clevo-p870dm-g-power-issue-update.829794/
    So after my laptop was ¨working¨ for a few months the GPU finally died died so I decided to replace it with a AMD Firepro m6100 Dell Precision MXM until I can get a new card.
    https://picclick.com/Dell-Precision-M6800-M6600-M6700-AMD-FirePro-M6100-272902889880.html
    I got the card wanted to test and see if I can at least post and nothing happened black screen and fans spin just like before and no beeps.
    So I assembled the parts, got new thermal paste, and got a new screen,
    1440p 120Hz B173QTN01.2.
    I get a black screen, the backlights come on, the fans both spin automatically but the CPU fan comes on before the GPU fan.
    When I do the FN+D trick all that happens is the is the laptop turns off and on.
    I tried taking out the CMOS battery waiting a few minutes then turning it on
    I have also tried reseating the RAM, changing ram slots.
    I took out the hard drives, battery and only booted off the Plug in adapter nothing has changed.
    The GPU I bought in New condition so it can´t be the GPU
    It might be the bios but I don´t know when I had the 1060 it worked until it just suddenly turned off and I could not turn it back on so I replaced it but the conditions haven´t changed.
    Don´t know if the motherboard is dead as the fans spin on their own but the screen stays black.
  2. Mr. Fox
    You cannot arbitrarily change to a GPU model that did not ship as a standard factory-installed option on a Clevo. You most likely need a BIOS mod. Clevo has not used AMD video cards in years, so I am doubtful the Firepro will work without a BIOS mod. You cannot even do that with a GeForce GPU. It is unfortunate that you cannot use any GPU that you want to use that physically fits the MXM slot, but that is how it works with Clevo. More likely that not, replacing the screen was unnecessary. If it wasn't an upgrade in specs that you will benefit from after getting a firmware mod to support the GPU, that might have been a waste of money.
  3. Reciever
    Reciever D! For Dragon!
    I personally havent seen any Dell cards working on Clevo laptops. Only MSi, not saying it will never work, just havent seen it.
    Bought in "new condition" doesnt mean much, especially when said card debuted in 2013 (m6100).
    Doesnt seem like you completely drained the battery although you kind of got close to doing that. Pull CMOS and battery, turn on laptop a few times (with no power) and leave overnight, turn on (without power) a few times and see if there is any change.
    Going to want to stick with known functioning cards into your clevo that it is known to function with when you are trying to troubleshoot.
  4. runix18
    runix18 Notebook Consultant
    The way I see things...
    1. you have an incompatible GPU (Amd Gpu will never work with P870 series due to incompatible EC)
    2. you have an incompatible display installed (you will need a bios mod, or dsanke bios mod flashed for that display to post)
    Solution. Get an inexpensive native supported GPU (gtx 970m), and see if it works with B173QTN01.2.
    rockman1216 likes this.
  5. rockman1216
    I bought the m6100 because it was suggested in one of the posts.
    By @DaMafiaGamer
    http://forum.notebookreview.com/threads/clevo-p870dm-g-power-issue-update.829794/page-2
    It was just a temporary test card was planning on upgrading to something much more powerful that's why I got the screen.
  6. rockman1216
    My bios is dsanke modded sorry forgot to mention.
  7. DaMafiaGamer
    DaMafiaGamer Switching laptops forever!
    The FirePro card does boot, even on the newer models of the P870, however it only boots on the dell vbios not the HP one. Just double check what bios is written on the sticker if there is one. If not what colour is the mxm card red or green?
  8. Meaker@Sager
    At least the fire pro cards don't use a funky packaged BIOS chip.
  9. rockman1216
    Should be Dell https://www.google.com/url?sa=t&sou...4QFnoECAkQAQ&usg=AOvVaw1xiW69C9RWzuJByz-1DHPw
    This is what I bought on eBay
    It's a Red Card
  10. stas.b85
    stas.b85 Notebook Guru
    It's all somple - an old AMD GPU doesn't support an eDP connection. 6100 support only 60Hz LVDS screen.
