Clevo p870 km1g gpu upgrade to rtx 2070
Discussion in 'Sager and Clevo' started by Statik60170, May 20, 2021.
  1. Statik60170
    Statik60170 Newbie
    hello I am asking for your help because I bought a p870 km1 g with a basic 1070, I received my 2070 installed in the pc except that it is not recognized in the bios and under windows I have mod the driver to be able to make it work, I lost the g sync functionality since how I can find it again and the gpu can be recognized directly in the bios without having to make a file mod for each driver update? I have the dsanke bios v 1.07.15. thank you in advance
    Sorry for my bad english im french.
  2. KKthebeast
    KKthebeast Notebook Consultant
    http://forum.notebookreview.com/thr...clevo-laptops-rtx-cards-now-supported.825558/
    https://drive.google.com/file/d/1Tr275Yl65ejq6E_aV8aYqk-v7_hSJJwF/view
    Caution: (I have the i9-9900KF with 2x 1080s SLI with G-Sync, not the 2070) but, I am running the P870KM_RTX.rom from the above link. (G-Sync works on the 1080s with the RTX rom)
    I would make sure that your BIOS matches the above BIOS version.
    First, I would try using NVCleanstall 1.9, (you can easily modify the driver with one line in the advanced section of the app) enable added unsupported card, and type the Hardware ID.
    This same issue happened to me on my old M18X R2, when Nvidia decided to stop including my modded 980m SLI setup in their driver inf. I have found no simple fix (unless you can flash another modded vBios... that changes the hardware ID to a compatible ID... compatible meaning pre-certified by Nvidia)
    Sent from my SM-G998U1 using Tapatalk
  3. Statik60170
    Statik60170 Newbie
    what do you want me to do bios level motherboard or vbios rtx? I installed the card with this software it works but paq of g sync and I would have to know the size of the pads and the modification of the heatsink of the 1070, I have already started to do it just for boot but there must be other modifications to the heatsink to make
  4. Meaker@Sager
    It's not a huge pain to do each update, laptopvideo2go does pre-modified packages.
  5. matyee
    matyee Notebook Deity
    Hi,
    Use dsanke 870KM1_rtx version, and you will be fine. I have done it with 2080, no bios mod is needed.
    GL
  6. KKthebeast
    For clarity sir, when you say no bios mod needed? Do you mean no hardware mod needed or no bios flash needed. Asking for myself and to help the OP
  7. Statik60170
    Statik60170 Newbie
    Yes but no g sync with it
  8. Meaker@Sager
    You won't get that back, it needs signing in the BIOS from Nvidia.
  9. Statik60170
    Statik60170 Newbie
    Ok and who i can flash the rtx bios to see if it can fix my gpu name in bios ?
  10. Meaker@Sager
    The name in the bios is just a string of text, it does not so anything.
