Clevo P775TM1-G questions
Discussion in 'Sager/Clevo Reviews & Owners' Lounges' started by Brian umphrey, Mar 5, 2019.
  1. Brian umphrey
    Brian umphrey Notebook Enthusiast
    I just bought a P775TM1-G with a 1080p g sync display. RTX 2080 and i7-9700k. Do i need to swap the motherboard in order to swap in a B173QTN01.0 17.3 inch Screen 3K 120HZ LCD Screen 2560x1440 EDP 40 PIN Non-Touch display?
    I really prefer to have a 1440p screen.
  2. Dr. AMK
    Dr. AMK Living with Hope
    Congratulations,
    No need to do anything with your motherboard, only the right screen and the right cable. And you can find all details about compatible screens in your service manual. And you can ask your seller.
  3. Brian umphrey
    I bought this from Pro Star computers but no one really speaks english well so was easier to come here to ask. What should i expect to pay for a 1440p screen? Will i lose G Sync? Is my brand new 1080 144hz G Sync screen worth reselling?
    Dr. AMK likes this.
  4. Dr. AMK
    Your screen is fine and you can sell it without problem, or you can just keep it as a backup spare part. You can use the 4K one if you need it.
    @Prostar Computer can you please give some insight.
    MiSJAH likes this.
  5. Brian umphrey
    Not planning to go 4k as in my opinion it isnt worth the low refresh rate. the 1440p screen seems like the sweet spot right now. Prostar doesnt offer a 1440p screen so i have to go aftermarket sadly
  6. Dr. AMK
  7. Brian umphrey
    joluke and Dr. AMK like this.
  8. MiSJAH
    MiSJAH Notebook Deity
    This Sansung 970 500GB is way too hot, right?
    What can I do to cool it?
    Thanks.
  9. Dr. AMK
    Dennismungai likes this.
  10. yrekabakery
    yrekabakery Notebook Virtuoso
    In addition to the heatsink, make sure you install it in the M.2 slot under the GPU fan as this area gets more airflow.
