Clevo P775DM3-G possible upgrade panel?
Discussion in 'Sager and Clevo' started by Etzubasa, Oct 19, 2020.
  1. Etzubasa
    Etzubasa Notebook Enthusiast
    Hello everyone, I'm always here to bother you, I wanted to upgrade my panel and I was thinking of buying these components, do you think it is possible?
    Spec my panel :
    Monitor
    Manufacturer............. LG Display
    Plug and Play ID......... LGD0469
    Data string.............. LP173WF4-SPF1
    Serial number............ n/a
    Manufacture date......... 2014, ISO week 0
    Filter driver............ None
    EDID revision............ 1.4
    Input signal type........ Digital (DisplayPort)
    Color bit depth.......... 6 bits per primary color
    Color encoding formats... RGB 4:4:4, YCrCb 4:4:4
    Screen size.............. 380 x 210 mm (17,1 in)
    Power management......... Not supported
    Extension blocs.......... None
    DDC/CI................... Supported
    MCCS revison............. 2.2
    Display technology....... TFT
    Controller............... RealTek 0x2796
    Firmware revision........ 0.16
    Firmware flags........... 0x0004003D
    Active power on time..... 523 hours
    Power consumption........ 0,05 kWh
    Current frequency........ 24,28kHz, 60,10Hz
    Color characteristics
    Default color space...... Non-sRGB
    Display gamma............ 2,20
    Red chromaticity......... Rx 0,637 - Ry 0,348
    Green chromaticity....... Gx 0,334 - Gy 0,628
    Blue chromaticity........ Bx 0,154 - By 0,050
    White point (default).... Wx 0,313 - Wy 0,329
    Additional descriptors... None
    Timing characteristics
    Range limits............. Not available
    GTF standard............. Not supported
    Preferred timing......... Yes
    Native/preferred timing.. 1920x1080p at 60Hz (16:9)
    Modeline............... "1920x1080" 138,000 1920 1968 2000 2070 1080 1083 1088 1111 +hsync -vsync
    Standard timings supported
    Report information
    Date generated........... 19/10/2020
    Software revision........ 2.91.0.1043
    Data source.............. Real-time 0x0100 - NB: improperly installed
    Operating system......... 10.0.19041.2
    Raw data
    00,FF,FF,FF,FF,FF,FF,00,30,E4,69,04,00,00,00,00,00,18,01,04,95,26,15,78,0A,0B,B5,A3,59,55,A0,27,
    0C,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,E8,35,80,96,70,38,1F,40,30,20,
    35,00,7E,D7,10,00,00,1A,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,FE,00,4C,
    47,20,44,69,73,70,6C,61,79,0A,20,20,00,00,00,FE,00,4C,50,31,37,33,57,46,34,2D,53,50,46,31,00,22
    Upgrade panel:
    EDP Cable :
    P775DM LCD 2K4K CAVO 6-43-P7751-020-1L 6-43-P7751-020-N EDP 40p UHD 120MHZ per P775DM P870DM P650/ p670/P655.
    Panel:
    AUO B173ZAN01.0 LCD Pannello di Visualizzazione Dello Schermo 3840(RGB)* 2160 40pins eDP
  2. Tech Junky
    Tech Junky Notebook Evangelist
    http://forum.notebookreview.com/threads/laptop-screen-upgrades.816139/page-38
    Yes it's possible!
    LP173WF4-SPF1 = https://www.panelook.com/LP173WF4-SPF1_LG Display_17.3_LCM_overview_21056.html
    If you take the outline size 385.95(W)×218.9(H) mm and compare model you listed for the right size you should be able to find a match that fits.
    https://www.panelook.com/modelcompare.php?ids=21056,25358 Shows the physical size is the same
    I will suggest though looking at the alternate models and comparing the features in case you run into a seller that's offering compatible panels in place of the specific model you're looking at as they tend to switch which model is being shipped. Verify the specific model you want is what you're going to get before ordering it.
    If you need the 30 socket --> 40 pin cable those can be an issue to find but, I did a replacement on a different model and was able to get both the panel & cable from kreplacement.com fairly easily after trying to track them down on different sites from China with different shipping times / costs. Ordering both from the same company makes things easier to get things done efficiently.
    Etzubasa likes this.
  3. Etzubasa
    Can you help me make the right purchase please.
  4. Meaker@Sager
    You'll need the cable for the 40pin and then the panel just has to match the dimensions as above, worth checking the connector position too.
  5. joluke
    joluke Notebook Deity
    My advice would be to go for the panel in my signature (AUO B173HAN03.1 (144Hz @ g-sync)) since it supports 144hz and if you use dsanke's BIOS , you can get gsync working (mine does with a 8700k cpu)
  6. Etzubasa
    I wanted to change the panel of my clevo because I replaced the i9 9900k with i7 8086k and I have a benq ew3280u 4k external monitor
    I changed the i9 9900k cpu to i7 8086k and wanted to change the panel to enable g-sync, as you can see from the nvidia control panel there is no g-sync.
  7. Meaker@Sager
    It depends on the base BIOS used to create the mod and what it had signed for G-Sync.
