clevo p775dm3-g help
Discussion in 'Sager and Clevo' started by Etzubasa, May 19, 2020.
  1. Etzubasa
    Etzubasa Notebook Enthusiast
    Hi everyone, I open this thread because I have purchased a clevo p775dm3-g with unlocked bios and gtx 1080 and supports up to 9900k with stock heatsink, if I mount an i7 8700k which heatsink should I buy? I have seen several on aliexpress, I want to do a job well done. PS: Thank you in advance or for your help and sorry my bad English.
    Be patient but he is my first clevo and i need a lot of information i hope you will help me.
    Spec:
    CPU: i7 6700k
    Graphics card NVIDIA Geforce GTX 1080.- 17 "4k IPS screen, 60 Hz.
    1 Thunderbolt + 1 USB-C port. - 4 USB 3 ports.
    2 * Mini-Displayport + 1 * HDMI (can be used together with the internal Display used, maximum 4 displays) - Killer E2400 Gigabit network card and Intel WLAN module - Integrated camera - Bluetooth - .
    2*Hard drive Sata.
    2 * PCIe NVME SSD.
    Heatsink 1 link:
    https://it.aliexpress.com/item/32963523618.html?spm=a2g0o.cart.0.0.4fd13c00NN2kpy&mp=1
    Heatsink 2 link:
    https://it.aliexpress.com/item/32998389700.html?spm=a2g0o.cart.0.0.19c53c00ciAOoV&mp=1
  2. Meaker@Sager
    You'll need the that fits your GPU as it's a single unit. If you plan to get RTX then the second one.
    Etzubasa likes this.
  3. Etzubasa
    For now i don't intend to insert RTX, I just wanted to change i7 6700k with i7 8700k, can you help me with the heatsink?
    Is it possible to insert the correct link for the CPU heatsink?
    Meaker@Sager Thank you for your help.
  4. Meaker@Sager
    Then go by the gpu you have as the layout is different. You won't use the RTX heatsink with a gtx card.
  5. Etzubasa
    Is it possible to insert the correct link for the CPU i7 8700k heatsink?
    Is the link heatsink link 1 correct for 8700K?
  6. joluke
    joluke Notebook Deity
    The stock P775DM3-G works good with the 8700k
    I have it and don't have a single complain
    Papusan and Etzubasa like this.
  7. KLICHO
    KLICHO Notebook Consultant
    I have stock heatsink p775DM3G with 1080 and 8700K delid temp max 81 on 4.7GHz and -150 uv
  8. Etzubasa
    Thanks you have been kind and sorry for my ignorance on the matter, but it is my first Clevo.
    Papusan and jc_denton like this.
  9. KLICHO
    No problem :) This is forum to change information and opinion
  10. Meaker@Sager
    A delid is going to net you the biggest benefit cooling wise.
